Integration along a loop in the base space of U(1) bundles
In summary, the conversation discusses a ##U(1)## principal bundle over a base space ##M## and its relation to physics phenomena such as Berry's phase. The main question is what determines the existence of a good gauge potential ##A## defined on a loop in ##M##, with the suggestion that the topology of the pullback bundle ##{f^*}P## on the loop may play a role. Additional thoughts are provided on the induced bundle over the circle, the existence of connections for principal bundles, and the role of the Chern class in characterizing a principal ##U(1)## bundle. The conversation also questions the definition of the Chern class and whether it is only defined on even-dimensional base spaces
lichen1983312
85
Let ##P## be a ##U(1)## principal bundle over base space ##M##.
In physics there are phenomenons related to a loop integration in ##M##, such as the Berry's phase
##\gamma = \oint_C A ##
where ##C(t)## is a loop in ##M##, and ##A## is the gauge potential (pull back of connection one-form of ##P## on ##M##).
It seems that if we can find an ##A## that is smooth and single valued on the loop, ##\gamma ## is well defined. Physics literatures always assume this is true. However, we know in general there may not be a smooth and single valued ##A## found over ##M##. Then my question is what determines there is a good ##A## defined on the loop?
My guess is that since ##f:C \to M## is a smooth map, so the topology of the pullback bundle ##{f^ * }P## on ##C## determines whether ##\gamma ## can be well defined on ##M##? i.e. if ##{f^ * }P## is trivial, then a smooth and single valued ##A## can be defined on ##C## in ##M##.
Is this right ? please help.
A couple thoughts.
- The induced bundle over the circle will be a smooth surface that is a circle bundle over a circle. There are only two such surfaces, the torus and the Klein bottle. Which is it?
- Over the circle minus a point,pp, the bundle is trivial. Near the two ends, a section approaches two possibly different points in the fiber over the omitted point,pp. Adjust the section by the action of U(1)U1 on the fibers so that the two points match up at pp and which continuously rotates to become the identity outside of a small interval around pp.
- Every principal bundle(over a paracompact space) has a connection.(standard theorem)- Every principal ##U(1)## bundle is uniquely characterized by its Chern class. If the Chern class is zero, the bundle is trivial. The Chern class is an integer cohomology class in the second cohomology group of the base space.-
lavinia said:
A couple thoughts.
- Over the circle minus a point,##p##, the bundle is trivial. Near the two ends, a section approaches two possibly different points in the fiber over the omitted point,##p##. Adjust the section by the action of ##U(1)## on the fibers so that the two points match up at ##p## and which continuously rotates to become the identity outside of a small interval around ##p##.
- Every principal bundle(over a paracompact space) has a connection.(standard theorem).
Hi Lavia:
Thanks very much, but what character characterize the circle bundle on a circle, I only know little about the Chern class, which seems to be only defined on a even denominational base space ?
lichen1983312 said:
Hi Lavia:
- The Chern class is defined for any complex line bundle/principal ##U(1)## bundle.
- One knows from the classification of surfaces that the only two surfaces that fiber over the circle are the torus and the Klein bottle. One proof is to use the theorem that the Euler characteristic of a fiber bundle over a compact path connected space with compact fiber is the product of the Euler characteristics of the fiber and the base space. The circle has Euler characteristic zero so the bundle has Euler characteristic zero. The only two surfaces with zero Euler characteristic are the torus and the Klein bottle.
One must prove that if the circle bundle is a ##U(1)## bundle then it must be a torus.
- A torus is the Cartesian product of two circles ##S^1×S^1## and so is a trivial circle bundle over the circle. ##U(1)## acts on the fibers by complex multiplication.
The Klein bottle is not a product of circles. It is the quotient space of the torus by the action of the group ##Z_{2}## that rotates the first circle by 180 degrees and reflects the second circle around an axis. This action is orientation reversing and the Klein bottle is not orientable. As a circle bundle over the circle, one can show using the Intermediate Value Theorem that the bundle does not have a section.
Hi Lavinia, Thanks very much, that is very helpful!
You are welcome.
lavinia said:
The Chern class is defined for any complex line bundle/principal U(1)U(1)U(1) bundle.
I have to ask this again, should the Chern class be only defined on a bundle whose base space is even dimensional?
And are the Chern classes defined on a ##U(1)## bundle on a circle?
Explain why you are asking again. What is the confusion?
I mean should the Chern class be a even dimensional form like 2-form, 4-form..., and the circle is one dimensional.
or you mean the 0-form is well defined?
May be I am confused about the definition of Chern number. Does the U(1) bundle on a cirlce have a Chern number?
I suspected this may have been the question.
The Chern class is an integral 2 dimensional cohomology class. It exists for any complex line bundle. It may be represented by a closed 2 form if the bundle is smooth.
The Chern number is the integral of the Chern class over a closed two dimensional manifold.
In general, a manifold may have many closed surfaces embedded inside it. One can integrate the Chern form over anyone of them. But these are not called Chern numbers.
Since every 2 form on the circle is zero, the Chern class of any ##U(1)## bundle over the circle is trivial. In homology terms, ##H^2(circle;Z)=0##.
Thanks very much for the explanation.
You are welcome.
BTW: If one has a complex vector bundle of higher complex dimension ##n## then there is a Chern cohomology class in each even dimension up to ##2n##. So a complex 2 plane bundle will have a Chern class in ##H^2(M;Z)## and ##H^4(M;Z)##. A 3 plane bundle will also have a 6 dimensional class.
A complex 2 plane bundle over a closed 4 manifold will have two Chern numbers. One is the integral of the second Chern class (the one in ##H^4(M;Z)##) and the other is the integral of the first Chern class (the one in ##H^2(M;Z)##) wedge product with itself. This idea generalized to all dimensions. If the bundle is the tangent bundle of the manifold then these are called Chern numbers of the manifold.
The tangent bundle of any closed oriented surface( e.g. a torus or a sphere )is a complex line bundle. The Chern class of the tangent bundle integrates to the Euler characteristic of the surface.
Related to Integration along a loop in the base space of U(1) bundles
1. What is a U(1) bundle?
A U(1) bundle is a mathematical construct used in topology and differential geometry to describe a space that locally looks like a product space. It is a fiber bundle with U(1) as its base space and a fiber that is also a U(1) group.
2. What is integration along a loop?
Integration along a loop is a mathematical operation that involves calculating the total sum or average of a function over a closed loop. It is used in calculus and differential geometry to calculate line integrals.
3. How is integration along a loop related to U(1) bundles?
Integration along a loop is used to define topological invariants of U(1) bundles, such as the Chern number. This allows for a deeper understanding of the properties and structure of U(1) bundles.
4. What is the base space of a U(1) bundle?
The base space of a U(1) bundle is a space that locally looks like a product space, with U(1) as its base and a fiber that is also a U(1) group. It is a fundamental concept in differential geometry and topology.
5. How is integration along a loop used in practical applications?
Integration along a loop has many practical applications in physics, such as in quantum mechanics and gauge theories. It is also used in engineering and computer science for applications like signal processing and image recognition.
  • Topology and Analysis
  • Differential Geometry
