Integration by parts and characteristic functions
raw
Given characteristic functions f and g on the intervals [1,4] and [2,5] respectively. The derivatives of f and g exist almost everywhere. The integration by parts formula says \intf(x)g'(x)dx=f(3)g(3)-f(0)g(0)-\intf'(x)g(x)dx. Both integrals are 0 but f(3)g(3)-f(0)g(0) is equal to 1. Why is this?
Characteristic functions equal 1 on the interval given and 0 everywhere.
I'm really not sure. Does it have anything to do with the discontinuity between 0 and for both functions? I'm really bad at these types of questions...
To apply the integration by parts formula, then we need the function to be differentiable everywhere...
There does exist a generalization of the formula where differentiability is not necessary, but we still require the functions to be continuous everywhere. Your example shows that we cannot generalize the "integration by parts"-formula to discontinuous functions...
micromass's explanation is the correct one for basic analysis. However, it is possible to make integration by parts make sense for very rough functions using more advanced ideas which go by the name of "distribution theory". WARNING: although distribution theory is perfectly rigorous mathematics, the explanation below is anything but, so is probably not useful to you except for talking to physicists.
There is a thing which physicists call a "delta function", and we mathematicians also denote by \delta but insist on reminding everyone that it isn't actually a function in the conventional sense. Informally (physicist time), imagine that \delta(x) is a function which is zero everywhere except at x = 0, where it is infinite. But it's "exactly the right size of infinity" so that when you multiply it by something else and integrate, it pulls out the value at that point: \int_{-\infty}^\infty \delta(x) f(x)\,dx = f(0).
In your setup, what happens that makes integration by parts work is that you realize we should put f'(x) = \delta(x - 1) - \delta(x - 4), g'(x) = \delta(x - 2) - \delta(x - 5): that is, the derivative of f is a positive "unit spike" at 1, a negative "unit spike" at 4, and zero everywhere else. Makes sense, right?
Then you wind up with \int_0^3 f(x) g'(x)\,dx = f(2) = 1, \int_0^3 f'(x) g(x) \,dx = g(1) = 0, and both sides of your equation are 1, just as you want.
Thank you both for your quick and helpful replies.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
