Integration by parts ln(x^2+14x+24)
The discussion focuses on integrating the function ln(x^2+14x+24) using integration by parts. The user initially sets u as ln(x^2+14x+24) and dv as dx, leading to a complex integral that they struggle to solve. Suggestions include factoring the quadratic expression as (x+2)(x+12) and using properties of logarithms to simplify the integration process. Additionally, it is advised to apply long division and partial fractions for the remaining integral. The importance of including the differential "dx" in the integral is also emphasized to avoid losing points in assignments.
cmantzioros
∫ ln(x^2+14x+24)
Integration by parts: ∫ udv = uv - ∫ vdu
I chose u = ln(x^2+14x+24) and dv = dx therefore
du = 2x+14/x^2+14x+24 and v = x
Then once I substitute, I get:
∫ ln(x^2+14x+24) = xln(x^2+14x+24) - ∫ (x(2x+14))/x^2+14x+24
Now I can't figure out how to integrate ∫ (x(2x+14))/x^2+14x+24. I've tried multiplying out, factoring. I thought I might have to use integration by parts again but it's not working out. Any help would be greatly appreciated. Thanks.
Try factoring
x^2+14x+24=(x+2)(x+12)
ln(ab)=ln(a)+ln(b)
for the method you used:
to integrate the remaining quotient, use long division and then partial fraction.
*by the way, you should put dx in your integral... some prof. take points off for that.
As they should, forgetting your differential is a crime!
And yes, christianjbs idea is quite easier
In fact, if you see ANY quadratic equation inside LN, factor it, even if the solutions are ugly. Makes things much easier.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
