Integration by Parts: Solving the Integral of Sqrt(x) * ln(x) with Limits 1 to 5
intelli
integral limit 1 to 5
integral of sqrt x * lnx dx
a = 1
b= 5
x (-1 + 2 Log[x])
11.99604193 but its not right
Not sure how you reached that answer but did you use
u=lnx and dv=x1/2 dx ?
so is this right
du = 1/x dx
v = 3/2x^3/2
and plug into the parts formula?
intelli said:
so is this right
du = 1/x dx
v = 3/2x^3/2
v=2/3 x3/2
check that back.
then yes put that into the formula.
rock.freak667 said:
v=2/3 x3/2
check that back.
yes so i get this is this right after integrating
2/3 x^3/2 ln x (between limits 1 to 5 ) - 4/9 x^3/2 (between limits 1 to 5) and
i get 9.602
i get 9.602
Your calculus looks correct, but somehow you're not coming up with the right number. Re-check your computations and you should get approximately 7.47.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
