Integration over a set in n-dimensional space
  • Thread starter Thread starter sphere1
    Integration Set
sphere1
Not a homework problem, but self-studying Example 1.2.24 from Hogg et al.'s Introduction to Mathematical Statistics (7th ed).
N/A
Example 1.2.24: Let C be a set in n-dimensional space, and let Q(C) = ∫...∫Cdx1dx2...dxn. If C= {(x1,x2,...,xn : 0 ≤ x1 x2 ≤ ... ≤ xn ≤ 1}, then Q(C) = ∫010xn0xn-1...∫0x30x2dx1dx2...dxn = 1/n!. (Apologies for the poor formatting of the integration bounds.)
I haven't the foggiest idea how to get to 1/n!. My solution for the latter integral is x2x3...xn. Even if I were to assume that [0, 1] were divided into intervals of equal length, giving x1 = 1/n, x2 = 2/n, etc., I get n!/nn, which I'm pretty sure doesn't reduce to 1/n!. My assumption is that I am somehow integrating the second integral incorrectly, but I'm not sure how. Any suggestions would be appreciated!
I suggest you start by solving the more general integral
I_n(x) = \int_0^{x} \int_0^{x_{n}} \cdot \int_0^{x_2} dx_1\, dx_2\ldots dx_{n}.
You can solve this by induction. The base case is $$I_1(x) = \int_0^x dx_1 = x$$.
Compute the integral ##I_n(x)## for the first few values of ##n## and try to see the pattern. Then show that it is the correct pattern by induction applying$$I_{n+1}(x) = \int_0^x I_n(x_{n+1}) dx_{n+1}$$
Likes Gavran and FactChecker
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
