Integration using inverse trig indentities?
Cpt Qwark
1.\int{\frac{sinx}{1+cos^{2}x}} \, dx
2.\int{\frac{1}{13-4x+x^2}} \, dx
Inverse trig identities.
For the first one, I'm not too sure about what to do with the sinx on the numerator and i have tried u-substitution to no avail (different answer). For the second one, I tried factorising but only had solutions for x\inℂ.
You can maybe try to start with the substitution u = cos(x) and reforming the integral. A second substitution will be necessary after the first substitution.
Second substitution is not necessary. It can be done in that first one.
For the second integral start by completing the square in the denominator.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
