Integration using substitution
Dro
Integrate: 6/(1+sqrt(7x))dx
the hint was that u^2=7x
by substituting u, i got the antiderivative of (12/7)(u/(1+u))du so i substituted again and ended up getting 12/7(1+sqrt(7x)-ln(sqrt(7x)+1)) but apparently that's wrong. please help!
Assuming that your work is correct in getting to an integrand of (12/7) u/(1 + u) * du, divide u by 1 + u using polynomial long division.
wouldnt it be easier to substitute another letter like w for 1+u instead? although this did not give me the right number. i don't really get how to divide u by (1+u)
Actually, I don't see anything wrong with your answer: 12/7(1+sqrt(7x)-ln(sqrt(7x)+1))
except that it is missing the constant of integration.
I get 12/7(sqrt(7x)-ln(sqrt(7x)+1)) + C, which differs from yours by a constant.
thank you very much! i actually can't put the +C because i have to put it in online but i changed my answer to what you had which differed from mine by the +1 i had and it said I as correct
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
