Interacting theory lives in a different Hilbert space [ ]
In summary, the conversation revolves around the use of Hilbert spaces in quantum mechanics, particularly in the context of interacting and non-interacting systems. The question of whether the same Hilbert space can be used for both types of systems is discussed, with some arguing that the same logical propositions can be asked in both cases while others point out the importance of considering the full spectrum of operators. The concept of unitary transformations is also brought up, along with the role of detraction (or subtraction) in QFT. Ultimately, the differences between the relativistic and non-relativistic cases are considered, with the conclusion that the use of Hilbert spaces in QFT may be influenced by the nature of infinite degrees of freedom and unbounded
  • #71
meopemuk said:
On the other hand, the renormalized QFT is highly predictive, while being inconsistent.
How is it inconsistent?
meopemuk said:
Note that despite textbook claims, the traditional QFT cannot say anything about the speed of propagation of interactions. The "commutators of fields outside the light cone" have nothing to do with the time interval between the cause and the effect. In order to evaluate the speed of interactions, one must have a theory possessing a well-defined Hamiltonian and unitary time evolution. As we discussed earlier, the traditional QFT does not have these pieces. It can only calculate the S-matrix and energies of bound states, which do not reveal any time-dependent information.
The investigation of the propogation of effects in QFT was performed by Segal and Guenin in the 1960s for specific models. Also Haag's algebraic apporach allows it to be treated in general, where you can show that effects do propogate at the speed of light.
  • #72
It is undisputable that renormalized QFT (such as QED) can calculate the S-matrix (i.e., the result of time evolution between - and + infinite times) very accurately. I think we also agreed that this theory does not have a well-defined finite Hamiltonian. Without a Hamiltonian it is impossible to calculate the finite time evolution. That's the major inconsistency I am talking about.
I would appreciate exact references. Though, I am rather sceptical, for the same reason: the lack of a well-defined finite Hamiltonian in renormalized QFT.
Perhaps you are talking about 2D models? I admit, I know almost nothing about them.
  • #73
Bob_for_short -> What do you mena by later on we discover that the probability of an elastic process is zero? What do you mean that QED predicts an event that never happens?
No one ever claimed perturbation theory is perfect and the ultimate answer to all QFT problems. It has its limits, but renormalization is not one of them.
What has the Taylor power series expansion got to do with the perturbative expansion of, say, QED?
Also, it is very interesting how you ask people to answer your questions whereas you have not answered to my question: what kind of mathematical objects are your quantum fields?
strangerep & DarMM -> As I understand it, the renormalization procedure a la Epstein & Glaser (and hence the "infinite subtraction" one) is not more ad hoc then, say, solving [tex]a x^2 + b x +c =0[/tex]. Let me elaborate this a bit. I'm trying to obtain an answer from my (perturbation) theory, and to get that answer I must extend my product of distributions to coinciding points where it is in general ill defined. Of course, I'll have to satisfy some conditions (causality and locality), but in principle this is "just" another mathematical problem one has to solve. Much like trying to get an answer about some physical problem which would involve the solution of the above (simple) equation. So in this sense, it does not appear more ad hoc than every other problem in physics. Comments?
meopemuk -> The vanishing of the fields commutator outside the light cone is precisely a statement about the finite speed of the propagation of signals. Don't know the details about interacting theories, but if you consider the simple free massless scalar quantum field you can compute the commutator, which is just the difference of the advanced and the retarded propagator, and study its support properties. And what you find out is that it is only supported ON the light cone, i.e. that "light travels at the speed of light". (I know a scalar field does not describe photons correctly, but the idea is the same - a massless particle travels at the speed of light, which is finite.) For the massive case, the commutator will not be supported only on the light cone, but it has causal support, i.e. on and inside the light cone. Outside the light cone the commutator vanishes identically. And this is just a mathematical fact which is a consequence of the hyperbolic character of the underlying field equations.
(You can find a discussion on causality for the free massive scalar field in Chapter 2.4 of Peskins & Schroeder. It's not really in the "rigorous QFT" spirit, but it is meaningful nevertheless.)
  • #74
I clearly write what I mean. First we calculate some elastic processes. On page 500 (I exaggerate, of course), when the IR divergence is treated, it is stated that the elastic cross section is identically equal to zero. So, instead of predicting zero for elastic processes the standard QED predicts some finite value (in the first non-vanishing order). That means a too bad start. If the exact value were 0.5 and the initial approximation would give 0.45, it would be OK. But the exact value is 0 and the initial calculation gives 1 (the probability of elastic process). It is too far from reality. Take any Taylor expansion around x0=0 and calculate it at very big x, say x=10. You will obtain the same blinder. Why not to take a Taylor expansion around a closer point, say, at x0 = 9.9. Then f(9.9) ≈ f(10) and the remaining corrections will be small.
The magnetic moment is a series in powers of alpha/2pi. I speak of its numerical precision.
DrFaustus said:
...what kind of mathematical objects are your quantum fields?
My quantum fileds? Oh, they are terrible distributions. What saves me is their coming with natural regularization factors (charge form-factors).
  • #75
Well I thought I would check in with this thread after not doing so for a while.
Bob_for_short said:
So, in the first non-vanishing order the standard QED predicts events that never happen. And it does not predict the phenomenon that happen always (soft radiation). Don’t you consider this theory "feature" as a complete failure in the physics description? Isn’t it a too bad start for the perturbation theory?
Not at all, it's exactly what should happen. The cross section for processes that include up to an energy [itex]\Delta[/itex] in observed soft photons takes the form
[tex]{d\sigma\over d\Omega}\biggr|_{\rm soft} = {d\sigma\over d\Omega}\biggr|_{\rm elastic}\left({c_1\Delta\over E}\right)^{\!\! c_2\alpha}[/itex]
where [itex]E[/itex] is the CM energy, [itex]\Delta[/itex] is the maximum energy of the soft photons, [itex]\alpha[/itex] is the fine-structure constant, and [itex]c_{1,2}[/itex] are numerical constants. This does indeed go to zero as [itex]\Delta[/itex] goes to zero. [itex](d\sigma/d\Omega)_{\rm elastic}[/itex] starts with the tree-level term, which is [itex]O(\alpha^2)[/itex]. So, expanding in powers of [itex]\alpha[/itex], one finds first the tree level term.
  • #76
What you wrote is called the inclusive cross section, and I speak of elastic one. The elastic one (the exact and experimental) equals zero rather than > 0. The QED's one on the tree level is > 0 which is wrong. You have to work hard to cope with the IR divergence to finally obtain a physically reasonable result instead of obtaining it automatically, if your theory "catches" the physics right.
Let me put it in another way: whatever momentum q is transferred to the electron, no soft radiation appears on the tree level. Is it physical?
  • #77
I agree that free particles move at the speed of light or slower. But this fact has no relationship to the issue of the speed of propagation of interactions or (what is basically the same) signals. In order to say something about the speed of interactions/signals you must have a well-defined interacting theory. In the simplest case you should consider two particles at a distance R and solve a time-dependent problem in which you perturb the position of the particle 1 at time t=0 and determine the time at which this perturbation reaches the particle 2. I don't think this kind of problem can be analyzed within renormalized QFT, due to the lack of a well-defined finite Hamiltonian. And I don't think that "vanishing of field commutators" is relevant to the solution.
  • #78
This thread has turned into a discussion of Bob For Short's theory. I remind everyone that personal theories can be discussed only in the IR section.
I'm locking this thread. If the OP feels that his question hasn't been adequately addressed before this thread was derailed, he should start another one.
