Interaction Between Light and Black Holes
In summary, it seems that if light approaches a black hole such that its trajectory passes through the center of the black hole, the gravitational force would be in the opposite direction, which would not allow the light to change direction and be kept in that general vicinity.
ScientificMind
48
Since light is entirely incapable of slowing down, what happens when light approaches a black hole such that it's trajectory passes through the exact center of the black hole? It seems, based on what I currently know, this would mean that the gravitational force pulling on the light would be in exactly the opposite direction that the light is moving, which would not allow for the light to change direction and be kept in that general vicinity.
I appreciate any help you may offer.
Astronomy news on Phys.org
Nobody knows what happens at the very center of a black hole.
All we do know is that the math of our best theories starts to give crazy results such as infinite density and curvature.
This predicament is sometimes called 'a singularity', but what the math describes is very unlikely to be a physical reality.
The singularity is not 'a thing', what it is, is a sign that out theories are incomplete and cannot predict what happens at such extreme density and temperature.
In all known circumstances, light cannot exceed the speed of light ever, it's a universal constant according to relativity, and it has been verified experimentally many many times.
The fact that we have this 'singularity' in a black hole doesn't mean Einstein is wrong, the most well accepted explanation, but still completely speculative at present, is that quantum effects come into play which banish the singularity.
rootone said:
Light cannot exceed the speed of light ever, it's a universal constant according to relativity, and it has been verified experimentally many many times.
Sure ? I think that a black hole may change all that stuff, we have tested with normal conditions, not on the real conditions of a black hole, and what if in the inside the rules just change?
I was adding to my previous post while you replied ...
Yes the rules may very well change if quantum effects start to become significant, but we don't know how exactly.
There is no reason to assume the speed of light changes though, there are many other possibilities.
The first thing to understand is that a black hole cannot be described in terms of classical gravity, where the effect of gravity is modeled as a force. Instead, you need to use General Relativity. In GR, gravity is the result of curved spacetime. Light (and all objects) follows what is known as a geodesic through spacetime. A geodesic is the shortest path between two points. In flat space a geodesic is simply a straight line. However, in curved space a geodesic is no longer a straight line but a curved line. A good analogy is to look at the surface of the Earth. Because the Earth's surface is a sphere, the shortest path between two points on the surface is a curved line known as a great circle.
The problem with black holes is that these geodesics literally disappear at the center of the black hole, at the singularity. This presents a problem because in order for GR to make any sense the path of geodesics must be smooth and continuous. An object cannot jump around in an abrupt, discontinuous way. A singularity breaks this smooth continuity, so we don't really know what lurks at the center of the black hole. Many believe that the singularity is an artifact of our incomplete knowledge of physics.
Llight maintains a constant speed in vacuum, gravity like motion, witll shift it frequency without affecting velocity. Your hypothetical photons streaming toward a black hole will be blue shifted by as much as a factor of 2 as it approaches. It is, however, doomed upon crossing the event horizon. It will never exit that region of space..
that sounds like the light, will stop completely (at least with reference to the black hole) which I thought was impossible. How does that work?
Yes, the light would be absorbed by the black hole just like matter gets absorbed, or eaten, if you prefer.
Exactly! - it shouldn't be possible.
This is the singularity which the math leads us to - something which is very unlikely to be physically real.
*Something* must be happening to prevent this situation, but we really don't have much clue what it could be.
'Quantum effects' are the primary suspect, but the truth is that we just don't know (due to lack of any evidence)
If you were to take this back to the 1940s, you will see that even Albert Einstein did not approve of such confusion. He stated that nature should not allow this to happen. Theorized mathematical equations suggest that the event horizon is so strong that it would take matter to the center faster than the speed of light. Black holes warp spacetime so much that time by itself is slower than the area around it by much greater factors. Speed can affected how we move through time very much. For example, comparing someone sitting to someone walking 5 mph is a time dilation of 3 to the negative 15 power.
Reference please. I find this claim surprising since the determination that you get a black hole - a region where matter and energy can enter but never exit - was made by Finkelstein in 1958. Einstein died in 1955.
Related to Interaction Between Light and Black Holes
What is the interaction between light and black holes?
The interaction between light and black holes is a complex phenomenon in which light is affected by the intense gravitational pull of a black hole. As light approaches a black hole, it is bent and distorted due to the strong gravity. The closer the light gets to the black hole, the more it is affected and can even be completely absorbed by the black hole.
How does the gravity of a black hole affect light?
The gravity of a black hole is so strong that it can bend the trajectory of light. This is known as gravitational lensing and it can cause light to appear distorted or even be redirected in a different direction. The strength of the gravitational pull also determines how much light is absorbed by the black hole.
Can light escape from a black hole?
Once light crosses the event horizon of a black hole, it cannot escape. This is because the gravitational pull is so strong that even light, which travels at the fastest speed possible, cannot overcome it. However, light can still be emitted from the accretion disk surrounding the black hole.
How does the interaction between light and black holes affect our understanding of the universe?
The interaction between light and black holes has provided us with valuable insights into the nature of gravity and the behavior of matter in extreme environments. It has also helped us observe and study phenomena such as gravitational lensing and the accretion of matter onto black holes, which can provide clues about the formation and evolution of galaxies.
What is the significance of studying the interaction between light and black holes?
Studying the interaction between light and black holes allows us to better understand the fundamental laws of physics and the behavior of matter in extreme environments. It also helps us to unravel the mysteries of the universe and expand our knowledge of the cosmos. Additionally, this research has practical applications in fields such as astrophysics, cosmology, and space exploration.
