Interaction of EM radiation with Glass
In summary: The answer to your question is that lead has a large nucleus which gives it a high positive charge and this makes it difficult for gamma rays to remove electrons from the atom. This is why lead attenuates gamma rays so well.
Jimmy87
686
Hi,
I wanted some clarification on the mechanism for how EM radiation interacts with standard glass, namely IR, visible and high energy (UV and X-ray).
Looking online most sources seem to say the band gap is around 10eV. Since visible light is about 1-3eV visible light will be transmitted.
IR however has a much lower energy yet is absorbed. Is this because you need to consider surface lattice vibrational modes instead of band gap theory. In that these vibrational modes of the lattice match the frequency of IR and are therefore absorbed?
Regarding UV is it right to now consider the band gap again in that UV has energies beyond the band gap of 10eV and will be absorbed by electrons in the ground state? Sources online say that some UV can penetrate glass and hence cause sun burn. Looking online I have found ranges for UV from 3-130eV so is it the UV photons between 3-10eV that get transmitted.
I also wondered how X-ray and gamma photons would interact with glass?
Thanks for any insights. This is just general curiosity and interest.
My best guess is that x-ray and gamma ray photons would either pass right through without much interaction, undergo an absorption where multiple electrons are ionized from their atoms from the very high amount of energy deposited, or they would scatter off of atoms in the glass in some fashion. I doubt glass is going to absorb many photons once you get into the x-ray range and beyond, so it is probably highly transparent in that part of the spectrum (as most things are).
Likes dlgoff, vanhees71 and Jimmy87
Where did @MeadowZ detailed answer go?
Does anyone know any detailed information about how high energy EM radiation interacts with lead glass that is used to block EM radiation like gamma whilst still being transparent to optical light.
I can only find this article in terms of band gap:https://www.tandfonline.com/doi/abs/10.1080/00207218908921075?journalCode=tetn20
Does adding lead to the glass change the band gap? Is band gap theory anything to do with how gamma interacts with lead glass or would it be a different mechanism? As @Drakkith said it would like cause a scattering or emission of an electron with regular glass so I’m keen to know the mechanism in lead glass? Thanks
Likes vanhees71
Glass becomes opaque just past the visible. Quartz goes a little farther.
The interactions of x- and gamma rays with glass is little different than from sand or other forms of silicon oxides.
Likes Jimmy87 and vanhees71
I don't know much about high energy radiation but gamma rays have energies of several MeV and band gaps are measured as several eV so the mechanism is very different. I think the interaction of the gamma with Pb nucleus will produce a shower positrons and electrons and other ionizing radiation that scatter like bowling pins in the alley.
Likes Jimmy87, Vanadium 50 and vanhees71
That answer was detailed but also vapid - plausible-sounding prose wrapped around a spam link to a “study help” web site. After several such posts in several threads it became clear that they were here to spam.
It’s best not to think too much about what happens to spammers…. Let’s just say that the problem has been taken care of.
  • Haha
Likes Jimmy87, Vanadium 50, hutchphd and 1 other person
Oh...and make it look like an accident.
  • Haha
Likes Jimmy87, vanhees71 and hutchphd
That’s not good. Was weird how it was the same as my post just with a few bits edited out.
Ah yes of course it is in eV. Are the only EM radiations that interact with band gap theory just visible and UV then? IR by lattice vibrational excitations and high energy through scattering and ionisation?
I have been looking for an answer as to why lead attenuated gamma so well. It was explained by lead having a large nucleus which also gives it a large positive charge due to the high number of protons. Therefore, electrons are harder to remove from the atom hence it can cause a large reduction in energy of the incoming gamma photon?
First, random words by a spammer to cover their spam is unlikely to help.
What do you mean by "so well"? Radiation length is 27 g/cm2. That's between sau lead at 5 and carbon at 42.
Likes Jimmy87
I don't know all the answers but I think in the final analysius at these energies the important factor is mass density (and cost). I have worked on some designs for medical devices that use Tungsten (Wolfram) instead of lead because of size (mass density 1.7 times that of lead). Actutally I think the prototype used W because the original design size was too damned small. Nothing magic about lead so far as I know, although it is at the end of most nuclear decay chains.
Likes dlgoff and Jimmy87
It's mostly electron density. High Z helps and high physical density helps.
Likes Jimmy87 and hutchphd
So the mass density is really just an indicator for the electronic (volume) density? Interesting idea...didn't think of that.
Likes Jimmy87
X-ray photons should have small enough wavelength to scatter (diffract) in the lattice
https://en.wikipedia.org/wiki/Bragg's_law
https://ceramics.org/wp-content/uploads/2009/03/warren_x_ray1.pdf
Gamma-ray photons should have enough energy to interact with the electron and the protons, and we could get say photo-pairproduction of electron and positrons, compton scattering and so on.
https://www.sciencedirect.com/science/article/abs/pii/S0029549316302539
https://www.nature.com/articles/s41598-022-07450-7
Likes hutchphd and Jimmy87
Say you irradiate a quantity of liquid diprotium vs. equal quantity of liquid dideuterium.
At triple point (14 K), diprotium is 77,2 g/l, which makes 38,6 mol/l. Dideuterium is 162,4 g/l, which makes 40,6 mol/l... about 5% more.
Does deuterium have over twice the absorption of protium, or only 5% more due to lower molar volume?
FAQ: Interaction of EM radiation with Glass
What happens when electromagnetic (EM) radiation interacts with glass?
When EM radiation interacts with glass, several phenomena can occur: transmission, reflection, absorption, and refraction. The extent to which each of these phenomena occurs depends on the wavelength of the radiation and the properties of the glass. Typically, visible light passes through glass with minimal absorption, while ultraviolet (UV) and infrared (IR) radiation may be more significantly absorbed or reflected.
Why does glass appear transparent to visible light?
Glass appears transparent to visible light because the atomic structure of glass does not absorb photons in the visible spectrum. Instead, these photons pass through the glass with minimal scattering or absorption, allowing us to see through it. The energy levels of the electrons in glass do not match the energy of visible light photons, so they do not absorb this light.
How does the refractive index of glass affect the behavior of light?
The refractive index of glass determines how much light bends, or refracts, when it enters or exits the glass. A higher refractive index means that light will bend more as it enters the glass from another medium, such as air. This bending occurs because the speed of light changes when it moves from one medium to another with a different refractive index.
Can glass block ultraviolet (UV) and infrared (IR) radiation?
Yes, glass can block certain wavelengths of UV and IR radiation. Standard window glass typically blocks most UVB and UVC rays but allows UVA and visible light to pass through. For IR radiation, standard glass can block some near-IR wavelengths but is less effective at blocking wavelengths in the far-IR range. Special coatings or treatments can enhance the glass's ability to block UV and IR radiation.
What is the effect of glass thickness on the transmission of EM radiation?
The thickness of glass can affect the transmission of EM radiation. Thicker glass generally absorbs and reflects more light, reducing the amount of light that passes through. This effect is more pronounced for certain wavelengths, such as UV and IR radiation. For visible light, the change in transmission with thickness is usually less significant, but very thick glass can still reduce light transmission due to increased absorption and scattering.
