Interesting sound-making hydrogen-burning device
In summary, the "Interesting sound-making hydrogen-burning device" refers to a unique apparatus that utilizes hydrogen combustion to generate sound. This device not only serves as a source of auditory effects but also showcases the properties of hydrogen as a fuel. Its innovative design highlights the intersection of science and art, demonstrating how combustion can produce distinct sounds and potentially serve educational or entertainment purposes.
Spinnor
431
There is an interesting video on the Wiki page for Hydrogen. A metal enclosure made of two funnels with a smaller hole at the top and a larger hole at the bottom is initially is filled with hydrogen gas. The covered holes are opened and the hydrogen escaping the top hole is lit. After a few seconds sound is produced. The pitch of the sound decreases and then there is a bang. Some interesting physics you might enjoy and puzzle over.
https://en.wikipedia.org/wiki/File:19._Експлозија_на_смеса_од_водород_и_воздух.webm
Likes Lnewqban
My guess.
The flame at the top is unstable as it burns above the resonant chamber top hole.
The speed of sound in H (1310 m/s) is about four times that in air, (343 m/s), (so MW H2 ≈ 1/42 that of air ?).
Each flame pulse, draws more air in from below, reducing H concentration until below 75% H. Sound frequency falls as air enters.
When the flash-point is reached, flame can enter the resonator, and consume the remaining 2H2 + O2 from the internal air.
Likes Spinnor and Lnewqban
Copied from that page and linked ones:
"Explosion of a hydrogen–air mixture. The bi-conical vessel is filled with hydrogen gas. The hydrogen is ignited and starts to burn, while air enters from the bottom, making an air–hydrogen mixture that is slowly air-enriched. When the critical composition is approached, the burning becomes unstable and produces a sound wave with a decreasing frequency (due to the oscillations of the air-enriching mixture). Once the critical composition is reached, the bang is inevitable."
"Explosive combustion of hydrogen. Escaping hydrogen is ignited, while the removal of the bottom cap allows air to enter. Eventually, the air mixes with the hydrogen inside the container, causing an explosion. A similar process occurs during a backdraft, with the introduction of oxygen and mixing with unburnt gases causing abrupt or even explosive combustion."
https://en.wikipedia.org/wiki/Backdraft
"At normal atmospheric pressure [the flammability limit] is 4% to 75%, based on the volume percent of hydrogen in oxygen it is 4% to 94%, while the limits of detonability of hydrogen in air are 18.3% to 59% by volume."
https://en.wikipedia.org/wiki/Hydrogen_safety
Likes Spinnor
FAQ: Interesting sound-making hydrogen-burning device
What is an "Interesting sound-making hydrogen-burning device"?
An "Interesting sound-making hydrogen-burning device" is likely a creative description for a hydrogen-powered musical instrument or device that uses hydrogen combustion to produce sound. This could involve the use of hydrogen as a fuel to generate sound waves through various mechanisms.
How does a hydrogen-burning device produce sound?
A hydrogen-burning device produces sound by utilizing the combustion of hydrogen gas. When hydrogen burns in the presence of oxygen, it creates an exothermic reaction that releases energy. This energy can be harnessed to create vibrations or pressure waves in the air, which we perceive as sound.
Is it safe to use hydrogen for sound-making purposes?
Using hydrogen for any purpose requires careful handling due to its flammability and potential for explosive reactions. Safety measures such as proper ventilation, controlled combustion environments, and the use of sensors to detect leaks are essential to ensure safe operation. When these precautions are taken, hydrogen can be used safely for sound-making and other applications.
What are the potential applications of a hydrogen-burning sound device?
Potential applications of a hydrogen-burning sound device include experimental musical instruments, educational demonstrations of combustion and sound principles, and unique sound effects for performances or installations. Such devices could also be used in scientific research to study the properties of sound waves generated by combustion.
How does the sound quality of a hydrogen-burning device compare to traditional instruments?
The sound quality of a hydrogen-burning device can vary widely depending on its design and the method used to produce sound. It may produce unique and novel sounds that differ from traditional instruments, offering new possibilities for musical expression. However, achieving precise control over sound quality and pitch might be more challenging compared to conventional instruments.
