Interference: Factors that reduce the widths of primary maxima
The discussion centers on how various factors influence the widths of primary maxima in interference patterns, ranking them from most to least effective as A>D=C>B. Doubling the wavelength of incident light doubles the fringe width, while doubling the frequency or slit spacing halves it. The relationship between the number of slits and fringe width is explored, leading to the conclusion that increasing the number of slits sharpens the peaks and reduces their width, as described by the formula Δθ = λ/(Nd). The conversation also touches on the intensity increase associated with more slits, which is noted to be a factor of four, contributing to the sharper appearance of the peaks. The derivation of the fringe width formula is emphasized as a well-known concept in diffraction and interference theory.
roya98864
An interference pattern due to a number of slits is incident on a screen. You are able to alter the number of slits, the spacing of the slits, and the wavelength of the light. Order the following adjustments according to which will most effectively reduce the widths of the primary maxima.
A: Double the number of slits
B: Double the wavelength of the incident light
C: Double the frequency of the incident light
D: Double the slit spacing
y_m = (m*lambda*D)/(d)
The ranked order from most to least effectively reducing the widths of the primary maxima is: A>D=C>B. I know that doubling the wavelength of incident light will double the width (y) of the fringe. This means that doubling the frequency of incident light will reduce the fringe width (y) by half. Doubling the slit spacing (d) should also reduce the fringe width (y) by half. I don't how much doubling the number of slits will cause the the fringe width to decrease. Is there any relationship between the number of slits and fringe width?
Thank you.
The way I know how to do this kind of calculation is to use the formula for the intensity of ## N ## equally spaced slits: ## I=I_o \frac{\sin^2(\frac{N \phi}{2})}{\sin^2(\frac{\phi}{2})} ## where ## \phi=\frac{2 \pi d \sin{\theta}}{\lambda} ##.
The width ## \Delta \theta ## is computed as follows: Primary maxima occur when the denominator is zero, along with the numerator. That means ## N \phi/2=Nm \pi ##. Meanwhile, the peak has a width determined by the location of the first adjacent zero in the numerator: ## N \phi'/2=Nm \pi+\pi ##. The result is ## N(\phi'-\phi)/2=\pi ## with ## \phi'-\phi \approx \frac{2 \pi d \Delta \theta}{\lambda} ##. With a little algebra, you get ## \Delta \theta=\frac{\lambda}{Nd} ##.
Likes etotheipi
The above formula ## \Delta \theta \approx \frac{\lambda}{Nd} ## would suggest that (A=C=D)>B would be the correct answer. ## \\ ##Giving it a little extra thought, doubling ## N ## will increase the peak intensity by a factor of 4, as well as reducing the width by one half, so the peaks will appear much sharper, and that may be why they selected the answer as A>C=D>B. That could also be why they used the word "effectively" when they phrased the question.:welcome:
Likes etotheipi
Thank. I apologize for not being clear in initial post. I thought the ranking order was A>C=D>B. This is not the answer key. Can you give a more detailed derivation of $$\Delta{\theta} = \frac{\lambda}{Nd}$$
My derivation is fairly detailed. One of my areas of specialization is diffraction grating type spectroscopy=what I showed is how this calculation is done starting with what is a very well-known formula for the interference intensity from a grating with ## N ## slits of spacing ## d ##. I think that formula is derived in most books that cover diffraction and interference theory in any detail.
The formula is a little tricky to use, because the denominator goes to zero in places=at the primary maxima=at those locations, you take the limit of the ratio of numerator and denominator, and get the result that ## I=N^2 I_o ##.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
