Intermolecular forces and temperature
In summary, at higher temperatures and constant volume, the effect of intermolecular forces on a van der Waals gas becomes less significant due to the constant correction to pressure and the smaller impulse imparted to atoms at higher speeds. This is because the exchange of momentum with the container walls, which determines pressure, decreases in significance. However, this is only an approximation and may not hold true for extreme temperatures.
PFuser1232
479
When the temperature of a fixed volume of gas increases (higher average kinetic energy), the effect of intermolecular forces becomes less prominent. That's very intuitive, but how can I understand this in terms of force, velocity, momentum and so on?
Science news on Phys.org
well bruh first of all I am a new guy and a very exploratory and curious student...lol
so it must be the weight decreases due to the expansion of gas or just spreading of molecules(force),it must be the density of air somehow effecting the speed thus stuff happening(velocity)...
so yeah that's what i think
If the gas you're talking about can be thought of as a van der waals gas, then the reason the effect of intermolecular forces becomes less important at higher temperatures (and constant volume) is that the correction to the pressure due to the intermolecular forces is constant at constant volume.
As the temperature increases at constant volume, the pressure increases, while the correction to the pressure remains constant, becoming less and less significant as a result.
For a more satisfying mechanistic reason, the faster moving the gas is, the impulse (force acted over time) imparted to a particular atom of the gas in the time it would take to travel a unit of distance is smaller at higher temperatures because that atom travels a unit of distance over a shorter time.
Because the exchange of momentum with the walls of the container is what determines the pressure, we can see that at higher temperatures the effect of intermolecular forces on the gas becomes less and less significant.
All this is an approximation though. If you got the temperature high enough to turn the gas into a plasma, or so that nuclear forces need to be taken into consideration, I couldn't say.
FAQ: Intermolecular forces and temperature
1. What are intermolecular forces?
Intermolecular forces are attractive or repulsive forces that exist between molecules. They are responsible for the physical properties of substances, such as boiling point, melting point, and viscosity.
2. How do intermolecular forces affect temperature?
Intermolecular forces become stronger as temperature decreases, causing molecules to move more slowly and become more tightly packed. This leads to changes in the physical state of a substance, such as from a liquid to a solid, as temperature decreases.
3. What is the relationship between intermolecular forces and boiling point?
The strength of intermolecular forces determines the boiling point of a substance. Substances with stronger intermolecular forces require more energy to break the bonds between molecules, resulting in a higher boiling point.
4. How does temperature affect the strength of intermolecular forces?
As temperature increases, intermolecular forces become weaker. This is because the increased thermal energy causes molecules to move more quickly and overcome the attractive forces between them.
5. What factors influence the strength of intermolecular forces?
The strength of intermolecular forces is influenced by the types of molecules involved, their size and shape, and the polarity of the molecules. Larger molecules and those with polar bonds tend to have stronger intermolecular forces.
