Chemistry Intermolecular forces between NO particles
Intermolecular forces between NO particles include dipole-dipole interactions and London dispersion forces, with emphasis on the latter. To assess the electronegativity difference between nitrogen and oxygen without specific values, one can recall basic trends in electronegativity across the periodic table. The non-symmetrical structure of NO indicates it is a polar molecule, which contributes to its intermolecular interactions. Both dipole-dipole and London dispersion forces play a role in the overall behavior of polar molecules. Understanding these forces is crucial for analyzing the properties of NO.
i_love_science
Identify the most important types of intermolecular forces present in NO.
intermolecular forces - London dispersion forces, dipole-dipoles forces, hydrogen bonding, ion-dipole forces
The answer is dipole-dipole and London dispersion forces, but I only chose London dispersion forces. How would you determine whether there is a large or small electronegativity difference between N and O? And therefore how would you determine whether the N-O bond is polar covalent or non polar covalent, not given electronegativity values?
Thanks.
Best approach is to remember some basic electronegativity values for most common elements (which as actually trivial: -4 for fluorine, then minus half for each next element while moving to the left though the periodic table, 2.2 for hydrogen and you have covered the most important ones).
Likes i_love_science
In the case of NO, I would also include covalent bonding, as N2O2 is in equilibrium with NO. You may argue whether this is really an intermolecular interaction, but at the end, all these distinction are artificial. E. g., all these interaction will contribute to the virial coefficients.
Draw the structure of NO and observe that it is non-symmetrical. Non-symmetrical molecules are generally polar.
Besides dipole-dipoles forces, London dispersion forces are also there. In polar molecules, cumulative effect of dipole-dipoles forces and London dispersion forces exists.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
