Internal pressure due to vessel collapse
In summary, the conversation discusses a plastic vessel filled with incompressible fluid and the impact of a pressure change on the vessel. The speakers mention the need to analyze the problem gradually and to consider the mechanical constitutive behavior of the vessel wall. They also suggest starting a new thread to discuss a related issue with pressure vessel calculations.
NMadura
Hey All,
I have a plastic vessel fully filled filled with an incompressible fluid (Water), at some time this vessel is impacted and crushed on one side (say 5% of the initial volume is lost).
Only, I know the volume isn't lost, the fluid (being incompressible) will exert pressure on all surfaces of my vessel causing the vessel to expand (where it isn't being crushed) and the pressure of the fluid will increase.
Is there a way of calculating this increase in pressure (maybe as a function of displaced fluid)?
In my mind I picture this as a water balloon on a flat surface, as I push my hand down on the middle of the balloon the water moves to areas not being compressed, eventually the maximum stress of the material is reached and the balloon material fails. How would one predict the internal pressure of the fluid?
Thanks for any help.
:welcome:
I would expect any such calculation to be dominated by the strength of the container walls.
A SCUBA tank would permit much higher pressure before bursting than a water balloon.
NMadura said:
Hey All,
Suppose the loading were applied gradually, rather than as an impact. This would be one way of starting to analyze the problem. If you can't solve the problem for a gradually applied load, you certainly won't be able to do it for an impactful load. The deformation of the vessel would have to be analyzed, under the constraint that the fluid is only slightly compressible (and described by the bulk modulus of the liquid). The analysis would involve differential force balances on small parcels of the vessel wall, based on the stress equilibrium equation (equilibrium differential force balance). The hard part of this is that, to do the calculation, one would need to study and quantify the mechanical constitutive behavior (stress/strain/displacement) of the material comprising the vessel wall, including large deformations (beyond the elastic limit) and displacements. Calculations like this can and are done, typically using Finite Element stress analysis. In addition to all this, one would also need to quantify the failure behavior of the vessel material in terms of a properly formulated failure criterion. In short, it's doable, but it ain't easy.
Can someone help me on these.
Pressure vessel with different pressure & temperature for shell side, jacket side & coil side. How to calculate the differential pressure? I need for minimum thickness calculation.
It would be better to start a fresh thread for this question .
When you have done that then please tell us much more about the practical problem that you are trying to solve
Likes Chestermiller
Related to Internal pressure due to vessel collapse
1. What is internal pressure due to vessel collapse?
Internal pressure due to vessel collapse is the pressure exerted on the walls of a container or vessel when it collapses due to external forces.
2. What causes internal pressure due to vessel collapse?
Internal pressure due to vessel collapse can be caused by a variety of factors, including high external pressure, structural weaknesses in the vessel, or sudden changes in temperature or pressure.
3. How does internal pressure affect the integrity of a vessel?
Internal pressure can cause a vessel to collapse or rupture, compromising its integrity and potentially causing leaks or spills. It is important for vessels to be designed and maintained to withstand internal pressure to prevent accidents.
4. How is internal pressure due to vessel collapse measured?
Internal pressure is typically measured in units of pressure, such as pounds per square inch (psi) or pascals (Pa). Specialized instruments, such as pressure gauges, are used to measure and monitor internal pressure in vessels.
5. How can internal pressure due to vessel collapse be prevented?
Internal pressure can be prevented by designing vessels to withstand expected pressures and conducting regular maintenance and inspections to identify and address any potential weaknesses. In some cases, relief valves or other safety mechanisms may also be installed to prevent excessive internal pressure.
  • Mechanical Engineering
