- #36
Ittiandro
- 54
- 3
Mister T said:Did you get the algebra to work out? Because the scheme you outlined in Post #22 is not what Nugatory described in #21 and then more recently in #27. The equations for length contraction and time dilation that you describe in #22 as the translation according to Lorentz are not the Lorentz transformation equations.
It's best to do exactly the same thing. Mark it off in segments of 100 km, too. Make the distance between the 100 km tick marks the same on both axes.
You are confusing yourself because you are thinking that this represents a light beam traveling a distance of 100 km when it instead corresponds to the the time it would take a light beam to travel a distance of 100 km. Lots of other things can happen in that time interval. A light beam traveling a distance of 100 km is just one of them, even though in the situation you happen to be considering there is no light beam doing that.
Maybe I can better describe my problem by referring to
http://demonstrations.wolfram.com/MinkowskiSpacetime/ Here we have 4 snapshots each showing graphically and algebraically how the invariant interval remains the same by shifting from one frame of reference to another starting from given values of x and ct in the 1st frame ( black)and a given v/c value .
Let’s look at the 1st snapshot , where x=0.584, ct=0.00 and v/c=.50.
We use the Lorentz transformation to translate the x and ct coordinates from frame X to frame X’ ( red) and the
Delta S^2=Delta ct^2- Deltax^2 formula to arrive at the same invariant value of -0.341 in both frames.It would help if both x and ct axes were graded in equal segments showing the spatial values of x and the spacetime values of ct..
In the black frame x =0.584 and ct=0.00. Translated into the second frame ( red) these coordinates become x=0.674 and
Ct=-0.337.
What I do not understand is how in each frame the coordinate x relates to the coordinate ct .
From what I understand, x and ct should be linked: there is a value of ct for each value of x. Could ct=0.00 in this snapshot be the same even if x changed? I don’t think so, but how does x translate into ct?
Also, I don’t understand how the x and ct coordinate would change in the graphic by changing v/c which is set to .50 in this case. There seems to be a sliding bar at the top to do this, but it is inactive,
Thank you
Ittiandro
