A Interpretation of Lagrangian solution (complex numbers)
The Lagrangian system has been successfully developed and solved, with a focus on holonomic constraints and the representation of variables in differential equations. The results show inconsistencies, particularly with the theta2 and "b" components, leading to the emergence of imaginary numbers, which are difficult to interpret. Filtering the results yields more realistic outputs when initial positions for "a" and "b" are consistent with radial displacement. The user seeks feedback and advice on addressing these issues and improving the accuracy of their solutions. Overall, the discussion highlights the challenges faced in interpreting complex results from a Lagrangian framework.
Mishal0488
Hi Guys
Finally after a great struggle I have managed to develop and solve my Lagrangian system. I have checked it numerous times over and over and I believe that everything is correct.
I have attached a PDF which has the derivation of the system. Please ignore all the forcing functions and damping for the system.
Essentially I have taken the holonomic constraint and represented (r+b) which I have taken as "B" as the subject of the formula, there after I am substituting the result into the derived differential equations.
The Matlab code is presented below, the "Statespace6" function is the representation of the differential equations while the main code is used to execute the code. There a number of plots developed (Please don't laugh at some of my spelling mistakes, I am going to fix these up later). The results do not make sense to me for the theta2 and "b" component of the system. In some instances there are imaginary numbers which are developed, which I am not sure how to interpret everything. Filtering in the results in most cases presents almost realistic results, however I am not completely convinced that the system is correct.
Further to this, the results which are understandable/realistic are developed when the same initial positions are imposed for "a" and "b" with regards to the radial displacement.
It would be nice to get an opinion of what I have done, and gather some comments, input and advice so I know what to look into next with regards to fixing my solutions.
function xp = Statespace6(t,x,r,L,k,m1,m2) theta1 = x(1); theta1_dot = x(2); theta2 = x(3); theta2_dot = x(4); a = x(5); a_dot = x(6); A = (a+r); %B R1 = 2*A*cos(theta1)*cos(theta2); R3 = 2*L*sin(theta2)+2*A*sin(theta1)*sin(theta2); one = -A^2+L^2; two = A^2*(cos(2*theta1)*cos(2*theta2)+sin(2*theta1)*sin(2*theta2)); three = -L^2*cos(2*theta2); four = -2*A*L*sin(theta1); five = -2*A*L*(sin(theta1)*cos(2*theta2)-cos(theta1)*sin(2*theta2)); R2 = sqrt(2)*sqrt(one+two+three+four+five); B = 0.5*(R1+R2+R3); %B = 0.5*(R1-R2+R3) %b_dot R1_dot = 2*(a_dot*cos(theta1)*cos(theta2) - A*theta1_dot*sin(theta1)*cos(theta2) - A*theta2_dot*cos(theta1)*sin(theta2)); R3_dot = 2*L*theta2_dot*cos(theta2) + 2*(a_dot*sin(theta1)*sin(theta2) + A*theta1_dot*cos(theta1)*sin(theta2) + A*sin(theta1)*theta2_dot*cos(theta2)); one_dot = -2*a_dot*A; two_dot = 2*a_dot*A*cos(2*theta1)*cos(2*theta2) + -A^2*2*theta1_dot*sin(2*theta1)*cos(2*theta2) + -A^2*cos(2*theta1)*2*theta2_dot*sin(2*theta2) + 2*a_dot*A*sin(2*theta1)*sin(2*theta2) + A^2*2*theta1_dot*cos(2*theta1)*sin(2*theta2) + A^2*sin(2*theta1)*2*theta2_dot*cos(2*theta2); three_dot = L^2*2*theta2_dot*sin(2*theta2); four_dot = -2*a_dot*L*sin(theta1)-2*A*L*theta1_dot*cos(theta1); five_dot = -2*a_dot*L*sin(theta1)*cos(2*theta2) - 2*A*L*theta1_dot*cos(theta1)*cos(2*theta2) - 2*A*L*sin(theta1)*2*theta1_dot*sin(2*theta2) + 2*a_dot*L*cos(theta1)*sin(2*theta2) - 2*A*L*theta1_dot*sin(theta1)*sin(2*theta2) + 2*A*L*cos(theta1)*2*theta2_dot*cos(2*theta2); R2_dot = sqrt(2)*(one_dot+two_dot+three_dot+four_dot+five_dot)/(2*sqrt(B)); b_dot = (R1_dot+R2_dot+R3_dot)/(4*sqrt(R1+R2+R3)); %differential equations %theta1 theta1_dotdot = (-2*m1*theta1_dot*a_dot*A-9.81*m1*sin(theta1)*A)/(m1*A^2); %theta2 theta2_dotdot = (-2*m2*theta2_dot*b_dot*B-9.81*m2*sin(theta2)*B)/(m2*B^2); %a a_dotdot = (m1*theta1_dot^2*A-k*a+9.81*m1*cos(theta1))/m1; %b b_dotdot = (m2*theta2_dot^2*B-k*(B-r)+9.81*m2*cos(theta2))/m2; xp = [x(2); theta1_dotdot; x(4); theta2_dotdot; x(6); a_dotdot; x(8);%b_dot; b_dotdot;]; end clc; clear; r = 1; L = 2; k = 353160; m1 = 3500/2; m2 = 3500/2; inc = 0.0001; SolverOptions = odeset('RelTol',1e-5,'AbsTol',1e-5); [t,y] = ode45(@Statespace6,[0:inc:2],[0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.1],SolverOptions,r,L,k,m1,m2); theta1 = y(:,1); theta1_dot = y(:,2); theta2 = y(:,3); theta2_dot = y(:,4); a = y(:,5); a_dot = y(:,6); %motion plots xx = (y(:,5)+r).*sin(y(:,1)); yy = (y(:,5)+r).*cos(y(:,1)); figure(1) hold on plot(xx,yy) title('Motion plot for mass1') hold off xx1 = (y(:,7)+r).*sin(y(:,3)); yy1 = (y(:,7)+r).*cos(y(:,3)); figure(2) hold on title('Motion plot for mass2 using unfiltered data') plot(xx1,yy1) hold off figure(4) hold on L1 = plot(t,y(:,8)) L2 = plot(t,a_dot) title('radial velocities using unfiltered data') legend([L1 L2],'b dot','a dot'); hold off figure(5) hold on L1 = plot(t,theta1) L2 = plot(t,theta2) title('Rotational displacement using unfiltered data') legend([L1 L2],'theta1','theta2'); hold off figure(6) hold on L1 = plot(t,y(:,5)) L2 = plot(t,y(:,7)) title('radial displacement using unfiltered data') legend([L1 L2],'a','b') hold off figure(7) hold on L1 = plot(t,y(:,2)) L2 = plot(t,y(:,4)) title('Angular velocity using unfiltered data') legend([L1 L2],'theta1 dot','theta2 dot') hold off %filter data Fs = 1/inc; %sampling rate Fc = 1/(Fs/2); %cut off frequency [b1 a1] = butter(4,Fc,'high'); b_new = filtfilt(b1,a1,y(:,7)); figure(8) hold on L1 = plot(t,b_new) L2 = plot(t,y(:,5)) legend([L1 L2],'b','a'); title('radial displacement filtereddata') hold off Fc = 1/(Fs/4); %cut off frequency [b1 a1] = butter(4,Fc,'high'); b_dotnew = filtfilt(b1,a1,y(:,8)); figure(9) hold on L1 = plot(t,b_dotnew) L2 = plot(t,y(:,6)) legend([L1 L2],'b dot','a dot'); title('radial velocity filtered data') hold off xx1 = (b_new+r).*sin(y(:,3)); yy1 = (b_new+r).*cos(y(:,3)); figure(10) hold on title('Motion plot for mass2 using filtered data') plot(xx1,yy1) hold off %holonomic constraint i = size(t); i = i(1,1); for j = 1:i H(j) = ((r+y(j,5))*sin(y(j,1))+L-(r+b_new(j))*sin(y(j,3)))^2+((r+y(j,5))*cos(y(j,1))-(r+b_new(j))*cos(y(j,3)))^2-L^2; end figure(11) hold on plot(t,H); title('Holonomic constraint using filtered data') hold off for j = 1:i H(j) = ((r+y(j,5))*sin(y(j,1))+L-(r+y(j,7))*sin(y(j,3)))^2+((r+y(j,5))*cos(y(j,1))-(r+y(j,7))*cos(y(j,3)))^2-L^2; end figure(12) hold on plot(t,H); title('Holonomic constraint using unfiltered data') hold off
Re: post #5 in the thread https://www.physicsforums.com/threa...ndulum-connected-through-a-rigid-bar.1007459/
For comparison please find attached Lagrangean of three coordinates x,y,##\theta##.
Thanks, I will digest proposal tomorrow.
I need to also apply a dynamic load which is always parallel to the springs and horizontal. The application of such may become a bit difficult with the proposed coordinate system.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
