I Interpretation of the Fourier Transform of a Cauchy Distribution
The discussion centers on the confusion surrounding the Fourier transform of a Cauchy distribution and its implications for sound. The inverse Fourier transform of a Cauchy distribution results in an exponentially decaying sinusoid, raising questions about the nature of sound produced from such a frequency distribution. Participants clarify that sound is generated as a time signal rather than directly from frequency inputs, and that while an initial exponential decay may occur, rephasing of frequencies over time leads to oscillating amplitudes rather than continuous decay. The analogy with Fourier Transform Infrared (FT-IR) Spectroscopy is explored to illustrate how phase differences affect signal detection. Ultimately, the conversation emphasizes the complexity of understanding sound wave behavior in relation to frequency distributions.
Jim Fowler
Hi,
I'm struggling with a conceptual problem involving the Fourier transform of distributions. This could possibly have gone in Physics but I suspect what I'm not understanding is mathematical.
The inverse Fourier transform of a Cauchy distribution, or Lorentian function, is an exponentially decaying sinusoid. What I don't get is this...
Can't I, in principle, play a sound through a speaker that has any frequency distribution I like? If I choose to continuously play such a sound with a Cauchy distribution of frequencies, what will I hear? Does the sound decay exponentially? If I'm continuously sending that combination of frequencies to my speaker, that doesn't make sense to me.
Any insights about what it is I'm missing would be most welcome.
Thanks in advance.
Mathematics news on Phys.org
Jim Fowler said:
Hi,
Thanks in advance.
Don't forget that the phase information in your signal. At time zero, all of the frequencies are in phase and the signal amplitude is at a maximum. As time goes on the signal decays as the phases move farther and farther out of alignment.
Likes FactChecker
Thanks, that does make sense, and I'm quite happy with that in a different scenario. Let me explain...What got me thinking about this was trying to get to grips with Fourier Transform Infrared (FT-IR) Spectroscopy. In an FT-IR instrument there's a Michelson interferrometer and a light source with a relatively broad spectrum of frequencies. The beam is split, a path length difference introduced and the two beams are recombined The signal that is detected depends on how the two beams interfere, which changes as you vary the path length difference, called the retardation. (You probably know more about spectrometers than me, I'm just recapping so we're all on the same page for the below...)
In spectroscopy it is normal to describe frequencies/wavelengths by wavenumber in inverse cm. The signal is a function of the retardation, not the time, and it's inverse cosine Fourier transform is the light source spectrum as a function of wavenumber. So the Fourier transform pair is between cm-1 and cm.
So far so good.
Now, it makes sense to me in this case that a spectrum with a frequency distribution (rather than discrete spectral lines) would give an eponential decay. As you say, at zero retardation all of the frequencies are in phase and construct. As you move the mirror in your interferrometer and so sweep the retardation (cm), the further you go the more wavenumbers start to deconstruct until at a large enough distance you have every phase difference under the sun and everything cancels.
That makes sense. There is still a constant light source but it all cancels out. I've seen it enough in the instrument data, it's referred to as the "centre burst" where nearly all the data is very close to zero retardation and drops off exponentially. But this is easy to picture what's going on. I can imagine running the mirror backwards from far to near, sweeping retardation from large to zero, and reversing the signal. I can picture that at a fixed retardation all the different sinusoidal waves have traveled slightly further in one arm than the other so for each wavenumber there is a phase difference in the two beams that depends on the wavenumber and the retardation. I can picture it because for a fixed retardation the signal is time invariant so I have 'time' to let the mental picture wander around the interferrometer. I struggle to have a similar picture in the case of sound
Mathematically, transforming wavenumber(cm-1) - retardation(cm) should be analagous to transforming frequency(s-1) - time(s) so I don't dispute the result but I'm struggling to have any intuition about what's going on in the case of sound waves. If the source is a single frequency then the signal would be a single sine wave that lasts as long as you're driving the speaker. If the source broadens just a little bit, but you're still driving the speaker indefinitely, does the volume of the sound produced really decay exponentially with time? I might have to do the experiment before I'll believe it :-)
You don't feed frequencies into a speaker, you send a time signal.
Likes jim mcnamara
Thinking a bit more about it, I might have found what is bugging you.
Imagine that you don't have a speaker, but an instrument that can produce many individual tones, close enough in frequency to be almost continuous. You then excite the tones with a frequency-dependent amplitude that is Lorentzian, leading initially to an exponentially decaying sound amplitude. But for a finite frequency range, after a while the signal will start to rephase, so the result will be an oscillating amplitude, not a forever exponentially decreasing amplitude.
Likes berkeman
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
