I Intersection of a 4D line and a 3D polyhedron in 4D
The intersection of a 4D line segment and a 3D polyhedron in 4D is indeed a point if they intersect, assuming they are not confined to the same 3D space. This conclusion aligns with the concept that a line in a higher dimension can intersect a lower-dimensional object at a single point. To prove this, one can analyze the situation using a coordinate system that aligns the 3D polyhedron with the axes. The reasoning parallels that of a line intersecting a plane in 3D, extended to an additional dimension. Thus, the intersection remains a singular point in 4D space.
LCDF
Is the intersection of a 4D line segment and a 3D polyhedron in 4D a point in 4D, if they at all intersect? Intuitively, it looks like so. But I am not sure about it and how to prove it.
Mathematics news on Phys.org
If they are not in the same 3D space then the intersection will be a point. You can even use the full 3 D volume and a full line and it will still be a single point.
You can look at the line segment in a coordinate system where the 3D object is aligned with three axes, for example.
Thanks. Is there a mathematical proof for your observation? A hint would also work.
My second paragraph is a description how to get to a proof.
It's basically the same as with a plane and a line in 3D, just with one more coordinate.
Likes LCDF
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
