Interval of convergence of power series from ratio test
  • Thread starter Thread starter zenterix
    Power series
zenterix
While reading a chapter from Simmons' "Differential Equations with Applications and Historical Notes" that reviews power series, I did not really understand a paragraph that tried to explain how to obtain the radius of convergence of a power series using the ratio test.
Consider the following power series in ##x##
$$\sum\limits_{n=0}^\infty a_nx^n$$
If ##a_n\neq 0## for all ##n##, consider the limit
$$\lim\limits_{n\to\infty} \left | \frac{a_{n+1}x^{n+1}}{a_nx^n} \right | = \lim\limits_{n\to\infty}\left |\frac{a_{n+1}}{a_n}\right | |x|=L$$
The ratio test asserts that this series converges if ##L<1## and diverges if ##L>1##.
These considerations yield the formula
$$R=\lim\limits_{n\to\infty}\left |\frac{a_{n+1}}{a_n}\right |\tag{1}$$
if this limit exists (we put ##R=\infty## if ##|a_n/a_{n+1}|\to\infty##).
Regardless of whether this formula can be used or not, it is known that ##R## always exists; and if ##R## is finite and nonzero, then it determines an interval of convergence ##-R<x<R## such that inside the interval the series converges and outside the interval it diverges.
I'm a bit confused by this snippet.
Why does (1) determine the radius of convergence?
I guess it is because of the following
$$\lim\limits_{n\to\infty}\left |\frac{a_{n+1}}{a_n}\right | |x| \tag{1}$$
$$=\frac{1}{\lim\limits_{n\to\infty} \left |\frac{a_n}{a_{n+1}}\right |} |x|\tag{2}$$
$$=\frac{|x|}{R}\tag{3}$$
Then, for ##-R<x<R## we see that the expression in (3) is less than 1 and so the power series converges.
I guess you've answered your own question.
Likes chwala and zenterix
