MHB Interval with Dirac function in a finite interval
The integral $\int_{-1}^2\sin \left (\pi (t-1)\right )\delta (-t+1)\, dt$ evaluates to zero because the Dirac delta function $\delta(-t+1)$ is non-zero only at $t=1$, which lies within the integration limits. By the properties of the delta function, the integral simplifies to $\sin(\pi(1-1))$, resulting in $\sin(0) = 0. The discussion highlights the use of the delta function and confirms that no further steps are necessary since the integral has already been resolved. The participants clarify the application of the delta function's definition in this context.
evinda
MHB
Hello! (Wave)
I want to calculate the integral $\int_{-1}^2\sin \left (\pi (t-1)\right )\delta (-t+1)\, dt$. I have done the following so far:
$$\int_{-\infty}^{+\infty}\sin \left (\pi (t-1)\right )\delta (-t+1)\, dt=\int_{-\infty}^1\sin \left (\pi (t-1)\right )\delta (-t+1)\, dt+\int_{-1}^2\sin \left (\pi (t-1)\right )\delta (-t+1)\, dt+\int_2^{+\infty}\sin \left (\pi (t-1)\right )\delta (-t+1)\, dt$$
We have that $\int_{-\infty}^{+\infty}\sin \left (\pi (t-1)\right )\delta (-t+1)\, dt=\int_{-\infty}^{+\infty}\sin \left (\pi (t-1)\right )\delta (t-1)\, dt=\sin (-\pi)=0$.
How can we continue? (Thinking) Do we use somehow the Heaviside step function? (Thinking)
Mathematics news on Phys.org
evinda said:
Hello! (Wave)
We have, by definition
[math]\int_a ^b f(x) \delta (x - c) ~ dx = f(c)[/math] if [math]c \in [a, b][/math] and 0 else.
In your case [math]t = 1 \in [-1, 2][/math], so [math]\int_{-1}^2 sin( \pi (t - 1) ) ~ \delta(-1 + t) ~ dx = sin( \pi (1 - 1)) = 0[/math]
as you said. I don't understand what there is to continue?
-Dan
-Dan
I didn't have in mind this definition. Thanks a lot! (Smile)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
