Invariant Spacetime Interval for Classical Spacetime
In summary: So while there is some notion of distance in classical spacetime, you cannot speak of a distance between two arbitrary spacetime points, right? You can only speak of the distance between points on the same time slice (this would be the spatial metric) or points at the same position slice (this would be the time-metric). You cannot speak of the distance of points on different time slices at different positions. Is this correct?Yes, this is correct.
AcidRainLiTE
90
In special relativity we have the invariant spacetime interval ds2 = dx2 - c2dt2. If we think about classical (non-relativistic) space and time as one spacetime in which the transformation between reference frames is given by the Galilean transformation, is there a corresponding spacetime interval that is invariant (the same when computed in any reference frame)?
No. There can't be, because the Galilean transformation leaves the time coordinate unchanged but changes the space coordinates. In other words, a Galilean transformation can change ##dx^2## between two given events, but always leaves ##dt^2## unchanged.
So then is it not possible to think of classical space and time as a single spacetime since we cannot assign a definite meaning to the distance between spacetime points (independent of reference frames)?
Actually it is possible and there is a lot of literature on the geometrization of Newtonian gravity and Galilean relativity. The difference is that instead of a single space-time metric, one has a time metric and a spatial metric which are separate from one another.
EDIT: And the reason for this is that Galilean relativity offers an absolute global time function that foliates space-time by the same simultaneity planes for all inertial observers whereas in SR the simultaneity planes foliating space-time are relativized to inertial observers.
Related to Invariant Spacetime Interval for Classical Spacetime
What is the Invariant Spacetime Interval for Classical Spacetime?
The Invariant Spacetime Interval for Classical Spacetime is a concept in physics that measures the distance between two events in spacetime, taking into account both space and time. It is a fundamental concept in Einstein's theory of special relativity.
Why is the Invariant Spacetime Interval important?
The Invariant Spacetime Interval is important because it is a fundamental quantity that is conserved in all frames of reference. This means that it is the same for all observers, regardless of their relative motion. It allows for the calculation of time dilation and length contraction in special relativity.
How is the Invariant Spacetime Interval calculated?
The Invariant Spacetime Interval is calculated using the Minkowski metric, which is a mathematical expression that takes into account both space and time. It is given by the formula:
Δs² = c²Δt² - Δx² - Δy² - Δz²
where c is the speed of light, Δt is the difference in time between two events, and Δx, Δy, and Δz are the differences in space coordinates.
What is the physical significance of a positive or negative Invariant Spacetime Interval?
A positive Invariant Spacetime Interval represents a spacelike separation between two events, meaning that the events are in different locations in space and cannot be causally connected. A negative Invariant Spacetime Interval represents a timelike separation between two events, meaning that the events are in the same location in space but at different times, and can be causally connected. A zero Invariant Spacetime Interval represents a lightlike separation, meaning that the events are on the light cone and can be connected by a light signal.
How does the Invariant Spacetime Interval change in different reference frames?
The Invariant Spacetime Interval remains the same in all inertial reference frames, which are frames of reference that are not accelerating. This is a fundamental principle of special relativity known as Lorentz invariance. However, in non-inertial reference frames, the Invariant Spacetime Interval can change due to acceleration or gravity, as described by general relativity.
