MHB Invertible Matrices: Why These Statements Are Not Correct
  • Thread starter Thread starter Yankel
    Matrices
Yankel
I have one more question, I have two matrices A and B, both squared and with the same order. And I have a scalar, a not equal to zero.
why are these statements not correct ?
1. If A and B are invertible, then
a\cdot (B^{-1}A^{-1}B)^{^{t}}
is not necessarily invertible
2. If A and B are invertible, then
a\cdot (A+B)
is not necessarily invertible, but if it is, it's inverse is the matrix
\frac{1}{a}\cdot (A^{-1}+B^{-1})
Thanks...
a\cdot (A+B)
Thanks...
For the first one, I'm going to assume WLOG that $A$ and $B$ are $n\times n$ matrices. if $A$ and $B$ are invertible, then $\det(A)\neq 0$ and $\det(B)\neq 0$. Furthermore, if $a\neq 0$ is a scalar, then
\[\det (a\cdot(B^{-1}A^{-1}B)^t)=a^n\det((B^{-1}A^{-1}B)^t) = a^n \det(B^{-1}A^{-1}B)=\frac{a^n\det(B)}{\det(B)\det(A)}=\frac{a^n}{\det(A)}.\]
This tells me that we'll always have $a\cdot(B^{-1}A^{-1}B)^t$ invertible provided that $A$ and $B$ are invertible with a scalar $a\neq 0$.
For the second one, it's true that if $A$ and $B$ are invertible, it may so happen that $a\cdot (A+B)$ isn't invertible. For instance, take $A=I$, $B=-I$ and $a=1$, where $I$ is the identity matrix. Then both matrices are invertible, but $A+B=O$, where $O$ is the zero matrix, which is clearly not invertible.
If $a\cdot(A+B)$ was invertible, then it wouldn't have that form for the inverse. We can see this is the case since
\[\left(a\cdot(A+B)\right)\left(\frac{1}{a}\cdot(A^{-1}+B^{-1})\right)=AB^{-1}+BA^{-1}+2I\neq I\]I hope this helps!
The world of 2\times 2 complex matrices is very colorful. They form a Banach-algebra, they act on spinors, they contain the quaternions, SU(2), su(2), SL(2,\mathbb C), sl(2,\mathbb C). Furthermore, with the determinant as Euclidean or pseudo-Euclidean norm, isu(2) is a 3-dimensional Euclidean space, \mathbb RI\oplus isu(2) is a Minkowski space with signature (1,3), i\mathbb RI\oplus su(2) is a Minkowski space with signature (3,1), SU(2) is the double cover of SO(3), sl(2,\mathbb C) is the...
