Is 1/x Integrable on Intervals Containing 0?
  • Thread starter Thread starter robertdeniro
robertdeniro
Prove that 1/x is NOT integrable on any intervals containing 0
would it be sufficient to say that the anti-derivative, ln x, blows up at 0? would this answer be rigorous enough for an analysis course?
or do i have to use some kind of partition argument?
You mean you can't say that since 1/x AND ln(x) do not exist at 0, it cannot be integrated over 0?
I believe you have to show that you can find a partition such that the upper sum is greater than any alpha ( > 0).
Basically, you show that the integral over zero can get as large as you want.
sorry, i have to show that its not improper riemann integrable
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
