MHB Is 2 the Only Even Prime Number?
  • Thread starter Thread starter mathdad
    Prime
2 is the only even prime number because it is greater than 1 and has no divisors other than 1 and itself. All other even numbers are divisible by 2, which disqualifies them from being prime. The confusion arises from equating prime numbers exclusively with odd numbers, which is incorrect. Prime numbers can include even numbers, with 2 being the sole even example. Understanding the definition of prime numbers clarifies why 2 holds this unique status.
mathdad
I know that 2 is an even number. I equate prime numbers with odd numbers. Why is 2 a prime number when it is listed in a group of odd numbers? Is 2 the only, even prime number? Why?
Mathematics news on Phys.org
A prime number is a natural number greater than 1 that only has 1 and itself as factors. Since 2 is greater than 1 and only has 1 and 2 as factors, it is therefore a prime number. It is the only even prime number because all other even numbers also have 2 as a factor. :)
Well, there's your problem! You cannot "equate prime number with odd numbers". For one thing, the odd number, 9, is NOT prime!
Do you know what prime numbers are? What is your definition of "prime number"?
Thank you for your help.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
