Is a falling elevator a valid inertial frame?
In summary, the conversation discusses whether a falling elevator can be considered a valid inertial frame according to the theory of special relativity. The consensus is that, locally and under certain conditions, yes, a falling elevator can be a good approximation of an inertial frame. However, if the elevator is extended over a large distance or time, the effects of gravity become more apparent and the approximation breaks down. Additionally, it is noted that there are no truly inertial frames in the real universe, but local approximations can be made in areas where gravity is negligible or nearly uniform. The discussion also touches on the effects of gravitational time dilation and length dilation in different frames.
Austin0
1,160
The title about says it. Is a body, (frame) free falling in a gravitational field a valid inertial frame as defined by SR?
Thanks
Is a falling elevator a valid inertial frame? The short answer is "yes".
The longer answer is "locally, approximately yes".
If the elevator is small enough, and you consider it over a short enough period of time, such that you can consider the "acceleration due to gravity" to be constant in magnitude* and direction throughout the elevator, then, yes, within those limits it is a very good approximation of an inertial frame. Any free-falling object within the elevator will move at constant velocity relative to the elevator, and the laws of physics, locally, look identical to an inertial frame in the absence of gravity. This is the Equivalence Principle of general relativity.
But if you try to extend your elevator coordinates to cover a large distance or a very long time, you'll find that distant free-falling objects don't move at constant velocity relative to you.
In general relativity we therefore say that the frame of a free-falling observer is locally inertial.
The rigorous mathematical treatment of this considers the calculus limit as the size of the elevator tends to zero.
_________
*Actually, to be pedantic, "constant in magnitude" isn't quite true either. It really should be "uniform" in the same sense of "indistinguishable from Born rigid acceleration". But "locally" the difference is as negligible as the true variation due to "real" gravity.
If the elevator is small enough, and you consider it over a short enough period of time, such that you can consider the "acceleration due to gravity" to be constant in magnitude and direction throughout the elevator, then, yes, within those limits it is a very good approximation of an inertial frame. Any free-falling object within the elevator will move at constant velocity relative to the elevator, and the laws of physics, locally, look identical to an inertial frame in the absence of gravity. This is the Equivalence Principle of general relativity.
If the elevator is extended to cover a large distance vertically wouldn't this also bring in a factor of relative acceleration due to the local gravitational difference at the extremes?
And also tend to cause stress and length elongation somewhat comparable to the Born hypothesis wrt acceleration?
From your responce can I assume that the measurement of light would be invariant and isotropic in relatively small systems?
From your responce can I assume that the measurement of light would be invariant and isotropic?
I stressed everything is a local approximation for small elevators, so you are right that for very tall elevators the approximation breaks down due to the tidal effects of gravity.
However, for "smallish" elevators, where tidal effects (due to gravitational variation) can be ignored but some other effects can't, you'll find the analogous "Born rigid" effects work the "wrong way round". The elevator is approximately inertial, and someone stationary on the ground is approximately undergoing Born rigid acceleration upwards. So the elevator measures approximately constant and isotropic light speed but the ground observer reckons light speed varies with height (relative to his own local coordinates), and "gravitational time dilation" that varies with height.
(By the way I made a minor edit to my last post since you read it.)
So does that mean that the only true inertial reference frame is a mathematical point undergoing acceleration due to a uniform gravitational field?
Well if you won't accept any approximations, in the real Universe there aren't any truly inertial frames, only local approximations.
Yes, an observer falling freely in a uniform gravitational field would define an inertial frame, but there aren't any truly uniform gravitational fields in the real universe (as far as I know). An observer moving freely in the complete absence of gravity would define an inertial frame, but there's nowhere in the universe you can completely escape gravity. Nevertheless, there are lot of places where gravity can be considered either negligible or almost uniform, so in those places you can certainly set up a local inertial frame.
(Note that you could escape gravity inside a hypothetical hollowed out planet, but that would still only be local to inside that planet.)
Is the stress and length dilation we are talking about here [for sufficiently large systems ]
due to tidal effects or the difference in the g factor due to relative distance from the center of the field??
Or am I incorrect in my understanding that the tidal forces are due to the ricci tensor (forces?) transverse to the orientation of the field center and that the g (acceleration?) was due to weyl forces radial to the field to that center?
I guess what I am asking in simple graphic terms is; would it get longer because it was being squeezed or because it was being accelerated faster at one end ,,,or both?
I have other questions relative to Born but I will wait for another opportunity
Thanks
How is this perspective? From an inertial frame, the elevator is accelerating , with velocity, doppler shift and dilation changing dynamically.
From this viewpoint it would seem to be the same as the Born hypothesis.
For the elevator to retain its proper length would require additional acceleration at the back/top. In principle the exact right amount would just compensate for the elongation without adding to the velocity at the front. I guess in principle the increased velocity could be expected to cause Lorentz contraction also .
What about gravitational length contraction , does EP apply in that regard as well?
Thanks
To make this easier to discuss, let's assume the elevator is freely falling down the elevator shaft of a skyscraper. (Of course we are assuming there is no air resistance or friction.)
Austin0 said:
From an inertial frame, the elevator is accelerating , with velocity, doppler shift and dilation changing dynamically. From this viewpoint it would seem to be the same as the Born hypothesis. For the elevator to retain its proper length would require additional acceleration at the back/top. In principle the exact right amount would just compensate for the elongation without adding to the velocity at the front.
No, this is why I said it's the "wrong way round". The elevator is the inertial frame, and it's the skyscraper that is Born-rigidly accelerating upwards. Accelerometers in the skyscraper determine that the skyscraper is undergoing proper acceleration and that the bottom of the skyscraper is accelerating a little more than the top in order to maintain a constant proper height.
You can't pick your own choice of which frame is inertial. It has to be the one in which you are "weightless", the elevator frame.
(Note: throughout the above, "inertial" is a shorthand for the technically more correct "locally inertial".)
These are really just two different ways of describing the same thing.
"Tidal effects" arise because the acceleration due to gravity doesn't vary in quite the same way as the "uniform acceleration due to pseudo-gravity" in Born-rigid accelerating frames in deep space. These tidal effects are of a smaller order of magnitude than the "Born rigid" effects, so over shortish distances they become negligible. The Born-rigid-like effects are "first order" effects (varying approximately proportional to distance), but the tidal effects are "second order" (varying approximately proportional to square distance, or smaller).
FAQ: Is a falling elevator a valid inertial frame?
What is an inertial frame?
An inertial frame is a reference frame in which Newton's laws of motion hold true. This means that an object in motion will continue to move at a constant velocity unless acted upon by an external force. Inertial frames are often used in physics to study the motion of objects without the influence of external forces.
Why is it important to consider if a falling elevator is a valid inertial frame?
It is important to consider if a falling elevator is a valid inertial frame because it affects the accuracy of our measurements and observations. If the elevator is not a valid inertial frame, the laws of motion may not hold true and our predictions and calculations may be incorrect. This can have serious consequences, especially in fields such as engineering and space travel.
Is a falling elevator a non-inertial frame?
Yes, a falling elevator is considered a non-inertial frame because it is accelerating. According to Newton's first law, an object in motion will continue to move at a constant velocity unless acted upon by an external force. In the case of a falling elevator, the force of gravity is acting on the elevator and causing it to accelerate downwards.
Can a falling elevator ever be a valid inertial frame?
No, a falling elevator can never be a valid inertial frame. In order for a reference frame to be considered inertial, it must be in a state of constant velocity or at rest. A falling elevator is constantly accelerating due to the force of gravity, therefore it can never be a valid inertial frame.
How does the concept of an inertial frame relate to the theory of relativity?
The concept of an inertial frame is a fundamental principle in the theory of relativity. In Einstein's theory of special relativity, the laws of physics are the same in all inertial frames, regardless of their relative motion. This means that the laws of motion must hold true in a falling elevator, even though it is a non-inertial frame. In the theory of general relativity, which includes the effects of gravity, inertial frames are used to study the motion of objects in a gravitational field.
