Is a Radio Wave Raser Feasible and How Would It Function?
  • Thread starter Thread starter ChrisAndre
The feasibility of creating a radio wave "raser," akin to a laser but for radio frequencies, is debated, particularly regarding the generation of coherent waves at low frequencies like 32 kHz. While masers exist for microwave frequencies, conventional lasers struggle at lower frequencies due to insufficient energy per photon for stimulated emission. Generating coherent radiation at 32 kHz is possible, but the long wavelength necessitates large antennas for efficient emission. The accuracy of such a system could be enhanced using stable frequency references, such as 32.768 kHz crystals. However, targeting precision remains a challenge due to the extensive wavelength, making it difficult to focus on small areas.
ChrisAndre
"Raser": Is it Possible?
Is it possible to make a "raser" (Radio Amplification by Stimulated Emission), or what we know now as a laser, but in the form of radio waves? How would this be achieved?
Depends what wavelength you are calling radio - the first 'lasers' were microwave
Microwaves? Cool! Say 32KHz frequency. Is there a way to generate coherent waves at this frequency? How accurate would this be?
Indeed...masers are microwave-frequency lasers.
At lower frequencies, a conventional laser probably isn't workable...not enough energy per photon to stimulate emission in the usual manner. Coherent radiation at these frequencies is easy to produce more directly, though...you could draw some analogies between a laser/maser tube and an oscillator circuit, though the mechanism is quite different.
32 kHz is far, far below microwave frequencies...it's at the bottom of the low frequency band. The main difficulty with generating coherent radiation at this frequency is its long wavelength...you need a large antenna to efficiently emit it.
How accurate would it be in what respect? There's plenty of 32.768 kHz crystals out there that would allow for an extremely stable frequency reference. With a wavelength of 9 km, you're not going to hit a small target with it.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Someone who shows interest in science is initially a welcome development. So are fresh ideas from unexpected quarters. In contrast, there is a scientific community that is meticulously organized down to the last detail, allowing little to no external influence. With the invention of social media and other sites on the internet competing for content, unprecedented opportunities have opened up for...
I am following someone on Youtube who has built a rocket shaped (4 proprllers) drone for the world speed record ... He was having problems with internal heat from electical control gear and battery inside the sealed rocket (about 1kw waste heat) Speed is 500km/hr , I suggested a 4mm hole in the tip of the nose and 8mm hole at rear which should alow sufficient air cooling .. I said this will increase thrust because the air exiting is hotter .. a bit similar to a ram jet ... was I correct...
