- #421
DrChinese
- 1,906
my_wan said:Yes in my string notation I ignored random detections not attributable to a causal mechanism per the "reality" postulate, and reordered them in nonrandom sequences. Trivial to simply randomize 00, change the remaining values accordingly. I did this to grab the main content in a nonrandom handwritten way to directly compare what was considered "real" about the coincidences. I'm a little strapped for time atm, but your issue with detections vs. coincidences is something that needs worked out. My string notation can't really have helped considering your version. I need to reformulate something you are more familiar with. You used a third observer, where I simply compared one pair of coincidences at one set of detector settings to different pair rather than a third observer.
I'll be back later, hopefully with a third person version, and also reiterate my earlier issues with realism as defined in paragraph a. Also again why EPR used it knowing its limitations. Your right we should take it piece by piece.
No problem on the time issue.
I use notation similar to yours in my examples when I am working things out. So try this for a dataset for 0/120/240:
Alice = [111111111111]
Bob = [000000001111]
Chris = [001100110000]
Notice that between any pair of observers, there are 4 out of 12 coincidences. That is 33%, the bottom limit for a local realistic theory. QM makes the predictions that there will be a coincidence rate of 25%.
See why I ask about datasets? If Bob's reality depends on whether Alice or Chris is the other observer, then you can have the correct relationships. But if Bob is blind to that, the relationships don't hold.
