- #176
DrChinese
- 1,913
billschnieder said:Again you are putting words in the "mouth" of EPR. They never provided a definition reality like the one you are suggesting. They said:... [snip]
...Note that they do not say the physical quantity being predicted, is itself an element of reality, just that it corresponds to one.
"If, without in any way disturbing a system, we can predict with certainty (i.e, with probability equal to unity) the value of a physical quantity, then there exists an element of physical reality corresponding to this physical quantity. It seems to us that this criterion, while far from exhausting all possible ways of recognizing a physical reality, at least provides us with one such way, whenever the conditions set down in it occur. Regarded not as a necessary, but merely as a sufficient, condition of reality, this criterion is in agreement with classical as well as quantum-mechanical ideas of reality..."
"One could object to this conclusion on the grounds that our criterion of reality is not sufficiently restrictive. Indeed, one would not arrive at our conclusion if one insisted that two or more physical quantities can be regarded as simultaneous elements of reality only when they can be simultaneously measured or predicted. On this point of view, since either one or the other, but not both simultaneously, of the quantities P and Q can be predicted, they are not simultaneously real. This makes the reality of P and Q depend upon the process of measurement carried out on the first system, which does not disturb the second system in any way. No reasonable definition of reality could be expected to permit this."
Funny. That sounds pretty, pretty, pretty, pretty, pretty close to:
"Two or more physical quantities can be regarded as simultaneous elements of reality when they can be predicted with certainty without disturbing the particle in any way - regardless of whether those elements can be simultaneously predicted."
Yes, I do agree that the phrase "corresponding to" is much much different from "regarded as". Oh gosh now, they actually said both didn't they...
And please, don't chop up poor ol' Bell any more than you already have. You're the one who thinks his work is "fatally flawed" or whatever you called it. As I have said many times, you're the local realist - why don't you define realism and then we can move on. Either your definition will agree with EPR or it won't. Obviously, if you are in the group that thinks the EPR is not sufficiently restrictive, then you don't agree with the EPR conclusion. If you do agree with their definition, then you should agree with the Bell conclusion. Go for it!
