I Is Capacitor Voltage Curved Like a Hyperbola?
  • I
  • Thread starter Thread starter vector222
    Curve Hyperbolic
The discussion revolves around the behavior of a capacitor in a circuit with a linearly increasing voltage applied across a series resistor and capacitor. Participants analyze the voltage across the capacitor and its potential hyperbolic nature, with one user presenting mathematical equations to describe the current and charge dynamics in the circuit. They derive expressions for the voltage across the resistor and capacitor over time, noting that the voltage across the capacitor does not exhibit a hyperbolic shape. The conversation emphasizes the need for further verification of the mathematical results and clarifies that the voltage curve is not hyperbolic. Overall, the analysis highlights the complexities of capacitor behavior in response to varying voltage inputs.
vector222
TL;DR Summary
is this a hyperbolic curve?
Ok Hi everyone!
I was working on what would happen if you apply a linear increasing voltage to a series capacitor resistor.
The question is : If the capacitor voltage is plotted, is the cap voltage curve hyperbolic?
I've done some plots on the cap voltage and it sure looks hyperbolic but I can't prove it.
Any thoughts on this?
If ##Q## is the charge on the capacitor the equation for the circuit reads
$$Q/C+R \dot{Q}=V(t).$$
Taking the time derivative gives
$$i/C+R \dot{i}=\dot{V}=A=\text{const}.$$
The solution of this obviously is
$$i(t)=C A+a \exp[-t/(RC)].$$
With ##i(0)=0## you get
$$i(t)=CA [1-\exp[-t/(RC)]].$$
Integrating, assuming ##Q(t)=0## gives
$$Q(t)=C U_C(t)=CA t + R C^2 A \{\exp[-t/(RC)]-1\}.$$
Likes etotheipi
Hi Vanhees71 !
I had come up with
Vres(t) = R/rc (1 - exp (-t/rc) where
Vres(t) = voltage across the resistor at time t
R = input volts per second across the series resistor capacitor
r= ohms
c = farads
Vres(t) = R/rc approaches a max value as t goes infinite
voltage across the cap at time t =
Vcap(t) = R(t) - R/rc (1 - exp (-t/rc) )
Have not verified this but it does look close to your math.
Still don't know if the cap volts are hyperbolic.
This looks pretty similar. It's not a hyperbola.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
