- #176
- 8,938
- 2,946
jartsa said:Let's consider a 1 cm thick clock hand. Can we say the under side of this clock hand always runs at the same rate as the upper side?
Can this much be said?
As I said, if two clocks A and B are SPATIALLY SEPARATED, then the question of which clock has a faster rate is coordinate-dependent. If they are at the same location, then the question is not coordinate-dependent.
Do you understand that for two clocks A and B that are spatially separated, and for two different coordinate systems (with time coordinates t and T), you can have
d[itex]\tau[/itex]A/dt > d[itex]\tau[/itex]B/dt
and also have
d[itex]\tau[/itex]A/dT < d[itex]\tau[/itex]B/dT
If A and B are at the same location, that is not possible.
