Is Coulomb's law valid in a non-inertial frame?
Coulomb's law does not hold in a non-inertial frame, even if charges remain static and the observer does not move. In such frames, the Coulomb force field becomes distorted due to fictitious forces. Specifically, under constant proper acceleration, radiation from static charges is not observed, but the field's distortion invalidates Coulomb's law. Therefore, the conclusion is that the expected Coulomb force will not be experienced as it would in an inertial frame. The discussion highlights the limitations of classical physics in non-inertial contexts.
xxxyyy
Hi,
I was wondering, if the charges do not move in a non inertial frame and I don't move too in this frame, will I see the same Coulomb force, some fictitious forces and radiation coming from these static charges?
Thanks!
A.T. said:
just a distorted Coulomb force field
Note that the distorted field means that Coulomb’s law is not valid. So the short but correct answer to the OP’s question is “no”.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
