Is Energy Conserved in General Relativity?
  • Thread starter selfAdjoint
  • Tags
    Energy Gr
In summary, Steve Carlip asserts that energy is not well defined in GR and suggests exploring non-covariant cases or considering energy to be non-local. However, Pete argues that locally, gravitational potential energy can always be transformed away and that this has nothing to do with the vanishing of tensors. Kurious suggests that the uncertainty principle does not apply to GR and that any attempts to unify QM and GR must take this into account. Pete also mentions a review article on Quasi-Local Energy and questions the need for gravitational fields to have energy.
  • #106
pmb_phy said:
You're speaking about something else. That is the total energy of the closed system consisting of the source of the g-field. We're talking anout the energy of a particle moving in a g-field. These are different topics.
Ok.
First off - The presence of a gravitational field does not imply the existace of spacetime curvature.
Why?
In the second place you're referring to the energy of the source of gravity and not the energy of a particle moving in a static gravitational field. In all cases where there is a static gravitational field P0 is a constant. This constant is called the "energy" of the particle.
Pete
Ok.
  • #107
gptejms said:
Thanks all of you for your inputs.I searched on the internet and found an article "Energy not conserved in GR"(by Baez,I guess) which explains that the stress-energy tensor doesen't satisfy Gauss's law if there is spacetime curvature.Is this not in contradiction with your statement above "GR conserves energy-momentum"?
Another question:- One of you(I guess pmb_phy) has said that energy is conserved in static fields. Why so?----a static field would also have accompanying spacetime curvature and Gauss's law wouldn't be satisfied.
I would assume that you found the sci.physics.faq about energy in GR
http://math.ucr.edu/home/baez/physics/Relativity/GR/energy_gr.html
a good source of information.
What you'll need to appreciate the argument here is in the FAQ, look for the line:
In certain special cases, energy conservation works out with fewer caveats. The two main examples are static spacetimes and asymptotically flat spacetimes.
Pete's been talking abut static space-times. There is indeed a conserved quantity that can be defined for a static space-time, even one that is highly curved, one that is not asymptotically flat. The only slightly odd thing you run into is that it's hard to set the right "scale factor" if you have a static space-time without asymptotic flatness. (AFAIK it's impossible to find any generally preferred scale factor for this conserved quantity without asymptotic flatness).
The simplest cases, BTW, like the Schwarzschild black hole, are both static AND asymptotically flat. That's the simple case I've been presenting the formulas for.
Of the two concepts, asymptotic flatness is, in my opinion, by far the most useful, and you'll find that that's how Wald, for instance, approaches the problem of energy in GR. MTW takes a different route to the same path - they discuss energy in terms of pseudo-tensors (also mentioned in the FAQ) - an approach that winds up working if and only if you have asymptotically flat space-times.
The two concepts do not conflict - when they both apply, they yield the same answer.
So Garth is right when he says that energy is not always conserved in GR - you do need some additional conditions, you can't define energy for an arbitrary space-time. But the specific example he gave to illustrate this was flawed - rather than going through the details, saying that we know that energy is conserved in asymptotically flat space-times should be enough to illustrate why the example is flawed.
Pete is also right when he says that energy is conserved if you have a static space-time (though I'm unclear if he's ever acknowledged that energy can also be conserved if you have asymptotic flatness in a non-static space-time.) Regardless of whether Pete acknowledges it or not, energy is conserved in this case.
  • #108
pervect - Agreed. But about your post #100 in this thread my understanding of the total system energy was taken from Weinberg, eq. 8.2.16 pg. 182.
Pete - From your post #103
Originally Posted by pervect
That's the covariant energy component of the energy-momentum 4-vector, i.e. [tex]P_{0}[/tex]
Yipes! That is an odd way to phrase that. Energy is energy and there is little reason to qualify it with "covariant". Energy is the time component of the energy-momentum 1-form.
Elsewhere you define energy as [tex]P_{0}[/tex] as it is this time element of four-momentum that is conserved if the metric time component is static. Yet a 1-form is the contravariant form of a vector.
Garth
  • #109
Thanks pervect for your answer.So,energy is conserved in the case of a star collapsing to a black hole(non-static spacetime with asymptotic flatness).(right?).
What about RW spacetimes?(I've picked up these terms reading the discussions here!)
  • #110
gptejms said:
Why?
Why would it? Miknd you - I'm going by Einstein's definition of "gravitational field" and nobody elses. Spacetime curvature, aka tidal force (i.e. Non-vanishing Riemman tensor) only means that there is a gravitational field present which can't be transformed away in a finite region of spacetime. The presence of a gravitational field, aka gravitational acceleration, is dictated by the non-vanishing of the Christoffel symbols (when the spatial coordinates are expressed in Cartesian coordinates). This does not require spacetime curvature. Thus a gravitational field can be "produced" by a change in spacetime coordinatges. But this is not true when the spacetime is curved, i.e. I can't produce spacetime curvature by changing coordinates.
pervect said:
..though I'm unclear if he's ever acknowledged that energy can also be conserved if you have asymptotic flatness in a non-static space-time.
In the first place I think that you're referring to the conservation of the mass of source of the gravitational field and not the conservation of the energy of a particle moving in the gravitational field. I was speaking of the later. In the second place I have not acknowledged what you speak of since I have not proved it to myself nor have I seen a proof ... and if its in Wald then I doubt I'd be able to follow it since that is an extremely hard text to follow. Someday. :smile:
Garth said:
Pete - From your post #103 ... Elsewhere you define energy as [tex]P_{0}[/tex] as it is this time element of four-momentum that is conserved if the metric time component is static.
I understand that and yes, that how its defined. By the way - why do you say that its how "I" defined it? Don't assume that it was I who presented this definition to the world of GR. :biggrin:
I simply don't think its a good idea to call it "covariant" energy or something like that - its simply "energy" and calling it something else like "covariant energy" gives the impression that its something different than "energy".
That is incorrect. A 1-form is a very different animal than a vector so its not a good idea to think of it as being a component of a different "form" of a vector. What you said here is like saying that a ket is a different form of a bra and that is certainly a bad way to look at bras and kets.
Pete
  • #111
Basically, yes. This works in the real world because our spacetime appears to be reasonably flat (on a global scale, it's obviously curved near massive bodies). So if you have a black hole that's reasonably isolated, energy is conserved as it collapses, when you add together the energy of the BH itself, any ejecta (looking at the Crab nebula as an example, there will be a fair amount of this in an actual collapse), and the energy of the radiation it emits (both electromagnetic and gravitational). All of this is measured from the viewpoint of a far-away observer, one where space-time is reasonably flat. A non-rotating black-hole wouldn't emit gravitational radiation as it collapses, but it rotating black hole is expected to emit gravitational radiation as it collapses.
BY RW space-time, you mean "Robertson-Walker"?
[edit]
I'm deleting my previous response here, I actually have to *think* about this one more before I answer!
[end edit]
  • #112
pervect said:
I'm *think* that the spatially flat Robertson-Wlaker universe is also asymptotically flat, but I'm not 100% positive.
The spacetime curvature for the RW spacetime has the same value everywhere. Since the spacetime is not flat anywhere it can't be asymptotically flat.
Pete
ps - I say "has the same value everywhere" but I'm not sure what that means per se. If I change frames from one inertial frame to another I will change the value of the spacetime curvature. But due to the homogeneity of the spacetime I think the curvature will still be the same everywhere. Yes? No? Maybe? To much to drink last night? :biggrin:
  • #113
I wasn't quite fast enough on the "edit" button, I see...
I am currently tending to think that energy is not conserved in Robertson-Walker space-times. The reason I think it's not conserved is cosmological redshift. If you emit some light, wait a bit, and measure it's energy in isotropic coordinates, you find that the light has lost energy.
If you don't use isotropic coordinates, you find that masses are accelerating away from each other which is also no good for energy conservation.
However, I can't quite pin down the reason why a spatially flat Robertson-Walker space-time wouldn't be asymptotically flat in the sense needed for energy conservation. It's very clear that there is a conformal isometry to flat space-time, because the metric is just -dt^2 + a^2(t)(dx^2 + dy^2 + dz^2).
However, there are 5 additional conditions that the conformal isometry must satisfy for a metric to be considered asymptotically flat. I suspect one of them is violated, but I can't pin down which one.
  • #114
Hi,
It may just be that energy/momentum conservation is the basic conservation rule everywhere, rather than two separate rules one for energy and one for momentum.
Since in most cases energy and momentum are both conserved seperately in most cases, this might be an appropriate idea.
In this way the lack of energy conservation on its own is no big deal.
This seems to suggest to me that the concept of forces arises from one continuous energy/momentum field, whose mode of energy/momentum transfer is a function of the basic structure of space/time in the neighborhood where such forces arise.
juju
juju
  • #115
"However, I can't quite pin down the reason why a spatially flat Robertson-Walker space-time wouldn't be asymptotically flat in the sense needed for energy conservation."
Bingo, you came around to my original posts back on page 3 of this thread. Look up what k asymptotic freedom means, things will become clearer.
But yes in general there is no ADM solution to FRW solutions. Let me say that again..
Global energy (defined canonically from the hamiltonian for the pedants) does not make sense in *general* in GR! Only in very specific formulations of asymptotic flatness where we can far field it, or in stationary metrics.
Worse.. gravitational energy due to matter is not relative in the strict sense we are used too classically. Why? B/c matter particles fix their definition of energy at infinity relative to the ground state vacuum (otherwise you get infinity for say the harmonic oscillator for a scalar particle). But in curved spacetime, there is no good way to even define a vacuum at some fixed point in space. Quantum mechanics bites us in the ass again.
  • #116
So I was right after all when I said that energy was conserved from the viewpoint of an observer in an inertial frame(corresponding to the asymptotically flat region)looking at the non-inertial frames from outside--the reason being that there are no pseudo forces in the inertial frame.
I also said that energy is not conserved for observers in the non-inertial frames(regions where spacetime is not flat) because there are pseudo forces in such frames which do work.However I'm not sure of this latter statement since pmb_phy and pervect didn't seem to agree.
  • #117
Pete
You mean non-vanishing Christoffel symbols associated with a gravitational field do not necessarily imply spacetime curvature-----this is news to me.Do others agree?
  • #118
If you take "space-time curvature" to mean a non-vanishing Riemann tensor, the statement is definitely true - an example is an accelerating rocket. The metric for an accelerating rocket is the Rindler metric
-(1+gz)dt^2 + dx^2 + dy^2 + dz^2
where g is a constant, the acceleration of the rocket. (This is in geometric units where c=1).
if you calculate the Riemann tensor and the Christoffel symbols for this metric, you'll find the Riemann is zero and the Christoffel symbols are not. (FYI some texts vary on exactly what they call the Rindler metric, but it doesn't matter to the point I"m making which uses the above metric as an example regardless of what name you choose to give it).
Cheat and use your favorite tensor program to calculate this sort of calculation, it's a pain to do by hand.
However, sometimes the term "space-time curvature" is loosely used to mean that the metric coefficients vary as a function of the coordinates. The metric above is curved in that lose sense, but not in the strict sense of having a non-zero Riemann curvature tensor.
  • #119
What text would I look this up in? I don't think it's in Wald :-(, his treatment of ADM mass is fairly superficial (his treatment of the Bondi mass is better).
I hope k asymptotic freedom is simpler than conformal infinity - the basic idea of making infinity a "place" is pretty clear, but the mathematical fine print is rather intricate.
  • #120
An inertial frame is a freely falling coordinate system. In such a frame of reference particles do not suffer accelerations unless there are specific non-gravitational forces acting on them. Such a frame can only be defined for a sufficiently small region around its origin, otherwise tidal forces will be experienced.
However, measured in such a frame, the energy of other particles outside this sufficiently small region will not be conserved in general. There is a confusion even in the definition of the energy of a freely falling particle in GR; as to whether it is [tex]P_{0}[/tex] or [tex]P^{0}[/tex], because although [tex]P^{0}[/tex] is the natural definition it is not conserved, even though no work is being done on the particle. Although [tex]P_{0}[/tex] is conserved in the frame of reference of the centre of mass of a static system, in general it is not so and this identification with energy is restricted and rather artificial.
The overall insight is that GR does not in general conserve energy, it is an improper energy theorem, it conserves energy-momentum instead.
The principle of the conservation of energy-momentum is not a concatenation of the principle of the conservation of energy and principle of the conservation of momentum; energy-momentum is a geometric concept in its own right, invariant under Lorentz transformations.
Energy and momentum are frame dependent concepts; therefore it is necessary to define a frame of reference, a preferred frame. in order to restore the principle of the conservation of energy.
Garth
  • #121
The tidal forces aren't a problem, if they approach the Newtonian tidal forces in the limit as you go to infinity. The standard definition of energy and energy conservation in GR can deal with tidal forces that approach Newtonian tidal forces as one goes to infinity.
It does appear to me that the expansion of the universe is not something that can be dealt with in this (standard) manner, however. This problem can only be dealt with by dealing with sections of the universe small enough that the cosmological expansion isn't important over the timescale studied.
Garth
The notion of a preferred frame of course requires a rather fundamental re-write of GR - one which a certain author just happens to have done :-).
We'll see how this new theory works out when the Gravity probe B results get back.
Meanwhile, I have to say that it is quite possible that the universe is screwy enough that the standard GR notion of energy conservation is the correct one - something that works over human time and distance scales, but something that doesn't work over cosmological time and distance scales.
