- #71
seto6
- 251
if a happens first and causes b to happen later in all frame we would see a then b. the events must have their order in all frame.
seto6 said:if a happens first and causes b to happen later in all frame we would see a then b. the events must have their order in all frame.
This is true, but one thing to note about this is that a lot of the CTC solutions require an infinite universe that has some "unrealistic" properties throughout, like a dense rotating cylinder of infinite length (the Tipler cylinder) or for the entire universe to have some nonzero rotation (the Godel metric, discussed here). If you want to create a finite region where CTCs are allowed in an otherwise "normal" universe, like time travel based on a traversable wormhole, a result by Hawking proved that you must use exotic matter which violates the "weak energy condition" (see third paragraph here), and at least in the case of wormholes some other energy conditions need to be violated too (see here, and note that quantum effects like the Casimir effect may not be sufficient). It's not known whether matter or fields that violate all these energy conditions are actually allowed by the fundamental laws of nature, so GR solutions involving them may not correspond to anything that could be realized in nature, even in principle (and this is before we get into the issue of whether CTC solutions might be one where GR's predictions would depart significantly from those of a theory of quantum gravity--some analysis suggests that in semiclassical gravity the energy density of quantum fields would always go to infinity on the boundary between the CTC region and the non-CTC region, which would indicate this is a situation where semiclassical gravity breaks down and a full theory of quantum gravity is needed)bcrowell said:It would be nice if relativity worked that way, but it doesn't. The field equations of GR admit solutions with closed timelike curves. In a spacetime with CTCs, you can't even define an ordering, much less ensure that it's coordinate-independent.
Sure, go for it.bcrowell said:@JesseM: It seems like we have two parallel threads going on here, one on SR and one on GR, which is making it hard to keep the discussion coherent. The SR posts are swamping the GR posts, and therefore a lot of us posting on GR are repeating ourselves or repeating each other. I'm going to start a separate thread for the GR stuff, and I hope you don't mind if I quote your (very interesting!) post #73 there in full.
Ken Natton said:So I suppose, to bring it back to the original subject of the thread, what you are telling me is that within the idealised constraints of an inertial reference frame, changing the sequence of events is not possible. Physical reality does not actually impose those constraints, and thus relativity of sequence is always possible. Once again, we have the undermining of the notion of cause and effect that worried me.
Can someone explain how the above works? How is it possible to have CTCs (i.e. return to a time in the past) in flat space?bcrowell said:Yes. If you simply take Minkowski space and identify the surface [itex] t=t_1[/itex] with the surface [itex] t=t_2[/itex], then you have a spacetime that has CTCs and zero intrinsic curvature everywhere.
kev said:Can someone explain how the above works? How is it possible to have CTCs (i.e. return to a time in the past) in flat space?
A universe with a closed spatial topology (so if you travel far enough in any direction you return to your place of origin) can have what seems to be a preferred global frame even if in any small region of spacetime the laws of physics work the same in any frame (see this thread), so I think the same would apply here. I don't really see this as a conflict with SR but I guess it depends on how you define "SR".yossell said:The reason this is not obviously coherent to me (bracketing the CTCs) is this: the surfaces picked out are dependent on a frame. In different frames, different lines of simultaneity. The simultaneity lines that are not parallel to this surface will, it seems, repeatedly curl around this surface, as the x-coordinate is not bounded, and the t-lines will loop around oddly too.
Is this just odd, or is it somehow in conflict with SR?
A single event could have several time coordinates in an accelerated frame. If the dead can rise from the grave once, why not several times?yossell said:I have a question about non-inertial frames: In the kinds of frames that you're talking about, one and the same space-time point will be assigned two different coordinates - e.g. the point of intersection of the lines of simultaneity. But does the concept of a frame allow for this to happen? The time of an event will be multivalued in such a frame. Do people know if this is ok?
Al68 said:A single event could have several time coordinates in an accelerated frame. If the dead can rise from the grave once, why not several times?
