pinball1970
- 5,545
No I don't mean in the physical sense. I have to use a situation to explain it however. (This is an outsider/lay view so it will sound simplistic but I would like to ask this)Stephen Tashi said:The only way to interpret that question becomes a familiar debate about whether numbers (and other mathematical concepts) were discovered or invented. You are suggesting that human beings developed language to describe something that already existed.
My take on that:
If we interpret "exist" to mean something that exists in a purely physical sense (like my coffee cup) then I can verify the existence of examples where (the current) concept of numbers models many of the physical properties well. Finding such examples requires not only finding examples of the noun number, but it also requires giving a physical interpretation to what we mean by "=", "+" etc.
I don't regard numbers as having an existence that physically causes 3+2 = 5. There are physical situations where this doesn't work (like computing the final volume after two volumes of different chemicals are added to the same flask). One can always object to such examples by saying that they are not what is meant by 3+2 = 5. This is a convenient type of a argument. It merely says that situations where a property of numbers works prove the physical existence of that property and situations where the property doesn't work are automatically disqualified from consideration.
An alien species sends a probe to our solar system and finds planets orbiting a star.
There is a quantity of planets and properties of that quantity that exist.
You can add other quantities to reach the total, you can times a quantity by another quantity to reach the total. (They like pluto)
Take away the planets and those relationships still exist, no matter what you call them.
The chemical reaction I would object that you are changing the quantities as you are adding them, losing some volume as gas or precipitate.
It works if you just consider two generic volumes x/2 and add them you end up with volume x.
It works if you completely remove all physical reality and consider two abstract objects x/2 and add them you ALWAYS end up with x.
Does that relationship just exist?
