Is f = n^2 a completely multiplicative function?
  • Thread starter Thread starter math_grl
math_grl
If f is completely multiplicative, then \sum_{d \mid n} f(d) is completely multiplicative is not true. There must be an easy counterexample for this yet I cannot come up with one.
call the sum F
consider
F(2)F(2)-F(4)
So you are saying that F(4) - F(2)F(2) is not 0 as it should be?
I was hoping for more an explicit function, f, such that F is not completely multiplicative.
What lurflurf said should work with any completely multiplicative f... I believe the key issue is that the two arguments, 2 and 2, have a factor in common.
For example, try what happens with two different primes, say 5 and 7:
F(5)F(7) = (f(1) + f(5)) . (f(1) + f(7))
and
F(35) = f(1) + f(5) + f(7) + f(35)
When you distribute the parenthesis in the first equation, and apply f(a) . f(b) = f(ab), you should get the same RHS as the second equation.
Now try with the values lurflurf proposed, and see what happens!
let f=n^2
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
