Is Fusion Considered a Chemical Reaction in Stars?
The discussion clarifies the distinction between chemical and nuclear reactions. It emphasizes that Dalton's law states that chemicals do not change into atoms during a chemical reaction, which is accurate as chemical reactions involve the rearrangement of electrons, not changes to atomic nuclei. In contrast, fusion, such as the process occurring in stars where hydrogen combines to form helium, is classified as a nuclear reaction. This process involves high temperatures and the collision of atomic nuclei, resulting in the formation of new elements. The conversation also touches on fission, where a heavier nucleus splits into lighter elements. Overall, chemical reactions maintain the same elements but rearrange them, while nuclear reactions involve fundamental changes to the atomic structure.
pinochet
im reading a chemistry text and its says in daltons law chemicals can not change into atoms during a chemical reaction.but if fusion is a chemical reaction then this is wrong beacuse in stars for example hydrogen combine with hydrogen to form helium .i guest i need a little clarification of what a chemical reaction is.
Chemistry news on Phys.org
Fusion is not a chemical reaction. It is a nuclear reaction. In chemical reactions nuclei don't change. Chemical reactions take place in low temperatures (up to several thousands K), while fusion requires temperatures many orders of magnitude higher (billions of K).
Likes pinochet and Titania
chemical reactions involve electrons
whilst
nuclear reactions involve particles inside the atomic nucleus - protons and neutrons
I think not. Chemical reaction involves two substances that are chemically combined to form a brand new substance which is different from its original properties while nuclear reaction involves two nuclei colliding with each other at high speed to form a new type of atomic nucleus. (Am I correct?) Just like the Sun, hydrogen fuses with hydrogen to form helium via nuclear fusion.
Likes pinochet
Nuclear reactions involve changes to atomic nucleii, transforming the atom into that of a different element.
Nucleii combining to form heavier elements is fusion.
Then there also is fission where a heavier element's nucleus breaks up.
Commonly a helium nucleus splits off from the heavy nucleus and the remainder becomes a lighter element, which may then undergo still further decay.
Chemical reactions do not involve nucleii, the elements remain the same but they are recombined in different ways.
Likes pinochet
thank you guys i get it now .
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
