Is fusion in an accretion disk of a black hole possible?
In summary, the accretion disk of a black hole can reach high enough temperatures for certain elements to fuse, but other processes such as the r-process and p-process may also be relevant. It is important to note that there are two types of accretion disks, one formed by collapsing stars and the other by wind or Roche lobe overflow, with the latter being less dense and potentially less observable in terms of nucleosynthesis. The collision of two high mass stars can also lead to the formation of a black hole, with the resulting collapse producing a dense accretion disk if there is enough angular momentum.
Irfan Nafi
34
I know that the accretion disk of a black hole gets hot enough for powerful emission of x-rays, but does that disk get hot enough for certain elements to fuse?
Astronomy news on Phys.org
Yet notice that what is meant by an "accretion disk" can be two rather different things-- we can have a disk forming as a rotating star collapses or two stars merge, which are going to be very high-density disks, and we have more standard X-ray binary disks, where you have Roche lobe overflow or a wind streaming in, and those kinds of accretion disks are going to be much lower density. So although nucleosynthesis would occur in both cases, it seems less likely to be observable or important in the low-density versions, and that might be what the OP is asking about. To what degree it occurs or is important in each situation will depend on the density and timescale, given that the temperature is indeed high enough. So certainly the answer is yes, nucleosynthesis occurs, but we should still distinguish supernova-type situations from the more standard meaning of a black hole accretion disk.
So it is possible but the accretion disk has to be dense enough. When a rotating star collapses to form a black hole the black hole should produce a GRB so any material in that GRB (that is close enough) has a probability to fuse only if the region is dense enough for atoms or nucleons to fuse. But how does the collision of 2 high mass stars result in a black hole?
When the masses of the degenerate electron core inside the two stars come together and exceed a limit, their gravity cannot be supported by degenerate electrons (because the electron energies go relativistic), and the cores collapse into either a neutron star or black hole (either one produces a dense accretion disk if there is enough angular momentum).
Likes Irfan Nafi
Related to Is fusion in an accretion disk of a black hole possible?
1. Can fusion occur in the accretion disk of a black hole?
Yes, fusion can occur in the accretion disk of a black hole under certain conditions. The intense gravitational forces and high temperatures in the disk can cause atoms to collide and fuse together, releasing large amounts of energy.
2. What elements are involved in fusion in the accretion disk of a black hole?
The elements involved in fusion in the accretion disk of a black hole are primarily hydrogen and helium. These are the most abundant elements in the universe and are found in large quantities in the accretion disk.
3. How does the fusion process in the accretion disk contribute to the growth of the black hole?
The fusion process in the accretion disk releases a significant amount of energy, which is then absorbed by the black hole. This energy contributes to the growth of the black hole and allows it to continue accreting matter from its surroundings.
4. Is there a limit to the amount of fusion that can occur in the accretion disk of a black hole?
Yes, there is a limit to the amount of fusion that can occur in the accretion disk of a black hole. This limit is known as the Eddington limit and is determined by the balance between the energy released from fusion and the gravitational force of the black hole.
5. How does the fusion process in the accretion disk affect the surrounding environment?
The fusion process in the accretion disk can have a significant impact on the surrounding environment. The high energy released can heat up the disk and surrounding gas, causing it to emit intense radiation and jets of particles. These processes can also affect the formation of new stars in the vicinity of the black hole.
  • Astronomy and Astrophysics
