I Is it possible to create an electromagnet to pull itself to Earth?
Creating an electromagnet that can pull itself to Earth is theoretically possible if it is positioned over ferromagnetic ground, as it would attract the ground and itself. The design must be under 500 pounds and capable of tripling or quadrupling its weight while using no more than 1,470,997.5 joules of energy. If the ground is not ferromagnetic, an external object, such as a large piece of steel, would be necessary for the electromagnet to exert a pulling force. The feasibility of this project hinges on the materials used and the energy constraints. Overall, the concept presents interesting challenges in physics and engineering.
Ghostxodus
TL;DR Summary
I want to know if it is possible to create an electro magnet that can pull itself to earth. Not just using gravity but create more weight if you know what I mean.
I am not a physicist by any means I just have this question that has been on my mind for a while and if anyone can help me with that it would be great. If it can be done I would like to try and attempt to do it. Some My goal is that it has to be like under 500lbs and be able to triple or quadruple its weight. While trying to use less than or equal to 1470997.5 jules. Thanks.
If your standing over ground that happens to be ferromagnetic, then yes, the electromagnet will try to pull the ground up and itself down. Otherwise, you'll have to put something in the ground for the electromagnet to pull on - like a ton of steel.
Likes davenn and berkeman
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
