I Is it possible to create linear acceleration using nothing but different moments of inertia beteen a wheel and axle?
  • I
  • Thread starter Thread starter BishopBrain
    Mechanics
The discussion revolves around the feasibility of creating linear acceleration using different moments of inertia between a wheel and axle, exemplified by the character Axel from the Twisted Metal video game series. Participants explore whether Axel could move if his center of mass is aligned with the axis of rotation, noting that while he could potentially roll, he would likely flip end over end. The conversation also touches on the mechanics of a Segway, emphasizing that motorization is necessary for movement. Additionally, the analogy of a tightrope walker is used to illustrate how torque can influence movement. Ultimately, the question remains whether movement is possible without external forces if Axel's center of mass is consistently on-axis.
BishopBrain
TL;DR Summary
The Twisted Metal video game series includes a character aptly named Axel, whose vehicle is just himself strapped to a pair of tractor wheels. This is the guy:
Most of my friends assume that in real life, he probably wouldn't be able to drive anywhere unless his feet were incredibly heavy, so that gravity would apply torque as his lower half swung forward--similar mechanics to a monocycle.
But one of us claimed that even if Axel's center of mass lay perfectly on the axis of rotation of the big wheels , he would still be able to move a little bit if he were so heavy that the moment of inertia of himself was significantly greater than the moment of inertia for his wheels. Axel would still be spinning sickeningly, but his contraption could move about at least a little bit.
Is this correct? Can two very-different wheels applying torque to one another via an axle generate linear motion from friction, even in the absence of any external forces tangential to the axle? We were skeptical, but couldn't figure out how to set up the system to test the math.
If he's rigidly attached to the wheels and he can flex his body to keep his center of mass forwards of the rotation axis then sure he can roll. He'd flip end for end as he does it, though, and I'm guessing the vehicle acts more like a Segway.
Obviously Segways are possible, but you need a motor.
Welcome!
What are those things attached to the shoulders?
Likes BishopBrain
Machine guns or missiles, I forget which.
Yes, in game he's motorized like a Segway. In-game he's also perfectly upright at all times, which is not terribly realistic...
The crux of my question is, if motorized and if his CoM is always on-axis, is movement possible for Axel. If he has a CoM off-axis, then he clearly can (in any number of ways), and I know how to draw up the free-body diagram to analyze it.
Sure, but the wheel hubs (with him) will spin opposite to the wheels.
There is some similarity with a tight rope walker carrying a pole.
The walker can accelerate his center of gravity rightward or leftward by exerting torque against the pole while his feet exert a counter torque on the rope.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
