Is it possible to distinguish between pure and mixed states?
In summary, the conversation discusses the possibility of distinguishing between an ensemble of pure states and an ensemble of mixed states through measurements on different axes. It is stated that for a pure state, there will be an axis where all members of the ensemble are spin up, while for a mixed state, there is no such axis. However, if the mixed state is maximally mixed, it is not possible to distinguish between the two ensembles experimentally. It is also mentioned that the density matrix formalism is more general than the state vector/wavefunction formalism and that an ensemble of mixed states can be seen as consisting of pure states. The conversation ends with a question about whether the information loss described by John Baez is related to the difference
Larry Pendarvis
106
Is it possible, in principle, for an experiment to distinguish between an ensemble of pure states and an ensemble of mixed states?
If so, how?
In particular, I am thinking of an ensemble of particles whose spin has been measured, one at a time, on the "Vertical" axis. The ensemble consists of an equal number of spin-up particles and spin-down particles. Thus there should be no entanglement. This is the ensemble of pure states.
The other ensemble has been prepared so that all particles are in a mixed state.
Would a black hole consisting of one ensemble be different in any way from a black hole formed from the second ensemble?
You can't distinguish between a pure and a mixed state by using only a single observable (or axis in your example).
You can if you perform measurements wrt to different axes. For a pure state, you will find an axis where all members of the ensemble are spin up. For a mixed state, you can't find such an axis. For a maximally mixed state, the amount of spin up doesn't depend on the axis at all.
Likes PeterDonis
You're kidding. Why does everyone want to make them all Up? I said it is an ensemble consisting of an equal number of pure Up and pure Down.
And you can measure them any way you like, I just want to know if you can get different results in SOME conceivable experiment.
Maybe I misunderstood you. So in the first case, you have an ensemble which is formed by mixing two ensembles which correspond to pure states of spin up and spin down wrt to a certain axis. In the second case, you have a ensemble of particles in a mixed state. If this mixed state is maximal (i.e. if the probabilities for spin up and down are equal), you have the same density matrix in both cases and there's no way to distinguish them experimentally.
If in the second case, the state is not maximally mixed, you can use the method of my previous post to distinguish between the two ensembles.
According to John Baez, each particle in the pure state is described by a wavefunction, not a density matrix:
http://math.ucr.edu/home/baez/physics/Relativity/BlackHoles/info_loss.html
"Take a quantum system in a pure state and throw it into a black hole. Wait for some amount of time until the hole has evaporated enough to return to its mass previous to throwing anything in. What we start with is a pure state and a black hole of mass M. What we end up with is a thermal state and a black hole of mass M. We have found a process (apparently) that converts a pure state into a thermal state. But, and here's the kicker, a thermal state is a MIXED state (described quantum mechanically by a density matrix rather than a wave function). In transforming between a mixed state and a pure state, one must throw away information. For instance, in our example we took a state described by a set of eigenvalues and coefficients, a large set of numbers, and transformed it into a state described by temperature, one number. All the other structure of the state was lost in the transformation."
And the first ensemble has never necessarily been separated into two other ensembles. It might have been a mixed-state ensemble each of whose particles was separately measured on the vertical axis and passed on, in the preparation process.
Larry Pendarvis said:
According to John Baez, each particle in the pure state is described by a wavefunction, not a density matrix.
That's interchangable. The density matrix formalism is more general than the state vector / wavefunction formalism. For a pure state, you can use both but for a mixed state you have to use the former.
What John Baez writes is in accordance with my first post, so you should try to understand what I wrote. Your posts give off an argumentative vibe to me. I'm happy to assist if you want to learn but I'm not interested in arguing with you.
An ensemble of mixed states is an ensemble of pure states.
A mixed state is of the form Σpi |ui><ui|. Take an ensemble of such states and you end up with the same form.
Thanks
Bill
Thanks
Bill
So are you saying that we can always refer to an ensemble of mixed states as consisting of pure states, which have already been measured, even though the mixed states have not been measured?
John Baez seems to be saying that the ensemble of pure states has more information than the ensemble of mixed states.
Does that mean that the information loss that John Baez ascribes to the difference between the density matrix and the wavefunction does not occur, and therefore there is no Information Paradox?
It's an ensemble of pure states, but that's not the same as the entire system, consisting of all the particles in the ensemble, being in a pure state.
How? You'll need to be more specific as to this preparation process.
We don't have a theory of quantum gravity so this question can't be answered. (I know you're interested in the black hole information paradox, but as I said in the thread in the relativity forum that spawned this one, we don't have an answer because we don't have a theory of quantum gravity, so there's no point in posing questions that assume there is a known answer on the issue.) This thread should stay focused on the question given in its title.
He's using "Up" in a different sense than you are; what he means is that, for a pure state, you will be able to find some direction in space (which will not, in your example, be the direction you are calling "Up") along which you can orient the measuring apparatus so that the measurement will always give the same result. For a mixed state, you can't.
Do you mean that, on some axis, an Up particle will give the same result as a Down particle? If that were true, then it would be easy to distinguish the two ensembles. But some say they have the same density matrix.
Do you know the actual technical definitions of these terms? Have you worked through a basic textbook on QM where they are discussed? If not, I would strongly suggest doing so.
That said, you are missing a basic distinction, which I mentioned in a previous post, between the state of individual constituents of a system, and the state of the system as a whole, including all the constituents. Note carefully that Baez, in what you quoted, says "Take a quantum system and throw it into a black hole". He does not say "Take an ensemble of quantum particles and throw them into a black hole". When he says the system starts out in a pure state, he means the system as a whole; he does not mean each of the individual particles composing the system. The individual particles may have no well-defined "state" at all (this will be the case whenever the state of the system as a whole is not a simple product state, which will be true of most quantum systems).
"What we start with is a pure state and a black hole of mass M. What we end up with is a thermal state and a black hole of mass M."
Or, for luminous matter, an oven.
As I said in the previous thread in the relativity forum: Baez' article is a statement of the problem, not a statement of the solution. You cannot help yourself to his scenario as a preparation process. Anyway, as I said in a previous post, this thread should stay focused on the title question, without bringing in the black hole information paradox. So we need a mundane preparation process for a mixed state that doesn't involve a black hole.
How would the (thermal) mixed state of the particles when they come out of the oven be described? How will the oven affect their spins?
I see. So even if you measure each particle in an ensemble, the ensemble is in a indeterminate state, although each of the particles has a known exact property. I presume this holds true for an ensemble of two particles?
No.
His argument is that the initial state is a pure state and the final state is a statistical mixture of pure states. A pure state is a state of maximal knowledge because you can't obtain more information about your system by performing measurements without forgetting something. If you have a statistical mixture, you can obtain more information by performing a measurement, namely which pure state the system actually is in. So if you start with a pure state and end up with a mixed state, you have no longer a state of maximal knowledge and in this sense you have lost information.
As PeterDonis writes, the question whether this is a real loss of information or an artifact of the missing quantum gravity description cannot be decided.
I should think that each one's spin would be indeterminate. Or can we also speak of those spins as being exact also? I have been told here that we cannot speak of a particle having an exact property until it is measured (in a fundamental way, not merely unknown to that particular experimenter). Thus I should think that the measured particles have exact spins and the others... don't.
kith said:
... the initial state is a pure state and the final state is a statistical mixture of pure states. A pure state is a state of maximal knowledge because you can't obtain more information about your system by performing measurements without forgetting something. If you have a statistical mixture, you can obtain more information by performing a measurement, namely which pure state the system actually is in.
So it would not be unreasonable to say that each particle in the thermal mixture emitted by the black hole has an exact pure spin, even before it is measured?
And neutrinos emitted in Hawking radiation in such a statistical mixture, is each one of them a pure states?
It doesn't lead to contradictions but given only the density matrix there are many inequivalent ways to assign pure states.
So the preparation procedure for the members of that ensemble is to pass them through a vertically oriented SG apparatus? So far, so good.
This preparation procedure produces a mixed state. Half the particles are aligned up along the measurement axis and half are aligned down, and if we pick anyone of them it's 50/50 which we'll get.
(Did you mean to say "superposition of up and down states" instead of "entanglement"? "Entanglement" makes no sense in this context.)
Prepared how? You've described the preparation procedure you used for the first ensemble. What's the procedure you're using for this second ensemble? We need to know that before we can tell you how measurements on it will turn out.
The (possibly alien, in a former scenario) scientist who measured the spins knows which ones are Up and which ones are Down. You are saying that the other scientist just doesn't have that knowledge; but the information exists. Is that, experimentally, exactly the same as an ensemble of particles of totally indeterminate spin?
Is this just semantics? It seems more fundamental than that.
I wanted to exclude the suggestion made earlier that entanglement might provide a way to distinguish the two ensembles. Entanglement made sense then, I am pleased that it no longer makes sense for this scenario.
Ok - let's start from scratch.
By definition a state is a positive operator of unit trace. A pure state, by definition is a state of the form |u><u|. A mixed state, by definition, is a state of the form ∑pi |ui><ui| ie the convex sum of pure states. It can be shown all states are either mixed or pure. It easy to see a mixed state is an ensemble of pure states where the pi is the probability of a random element of the ensemble being the pure state |ui><ui|. Now if you take an ensemble of mixed states obviously you end up with another mixed state. If pk is the probability of mixed state k = ∑pik |uik><uik| in that ensemble the probability of state |uik><uik| in the ensemble is pk*pik so the overall mixed state is Σpk*pik |uik><uik| where the sum is over i and k.
However your question in the title is if its possible to tell the difference between mixed and pure states. Of course it is - in theory from a large ensemble of systems prepared that same way to be in the same pure state, by observing each system to see if its in that state, providing you get a yes on each observation and the ensemble is very large you can say what the state is. If it was a mixed state you would not get a yes on each observation. Or rather its a vanishingly small probability of that being the case - but that probability can be made as small as desired because the ensemble can be made as large as desired.
Thanks
Bill
That's not at all what I said. Once again, have you actually looked at the technical definitions of these terms in a textbook? The questions you are asking indicate that you do not understand the terms you are using very well.
If you measure each particle in an ensemble, then the ensemble's state is just a product state, the product of the measured states of all the particles. This is a perfectly determinate state. (I am assuming that we are only interested in the particles' spins, not any other properties. I am also assuming that the particles are distinguishable, which just means we are able to keep track of which particle is which. This isn't really a good assumption in general, but for this discussion I don't think we want to bring in the added complication of quantum statistics.)
Why? Suppose each particle's spin was measured before the particle was put in the oven. Does the oven change the particles' spins? (Assume there is no magnetic field or anything like that in the oven.)
But if you prepare a particle in a certain state (as in your scenario, where you specified that half the particles were prepared as Up and the other half as Down), then you have measured it. Preparation and measurement are the same thing. As long as you don't subject the particle to some interaction that affects the prepared state (for example, measuring its spin in a direction different from Up-Down), it will stay in that state.
It obviously can't if you specify a scenario in which there is no possibility of entanglement. But that just means you picked a special scenario; it doesn't mean entanglement is not relevant to the general question you are asking.
Exactly. Someone has done the measurement (preparation) of Ensemble A.
Is it possible to prepare an ensemble of particles that are in some kind of Indeterminate spin state? If that is possible, then that is Ensemble B in my scenario. If that is not possible, then it seems that we can always properly refer to every particle as having a definite spin, although of course we might not know what the value is yet.
Or not, if we set up an unattended Stern-Gerlach machine so there's nobody to do the knowing... But it is the same preparation procedure either way.
The way quantum mechanics works, it gives you a set of rules for calculating the statistical distribution of measurement results across an ensemble that has been prepared in a particular way. Whether someone is watching the preparation procedure or not is irrelevant.
I don't know what it means to say "the information exists"... But it is indeed true that under the preparation procedure that you have described, the downstream scientist doesn't know which particles in the ensemble were deflected upwards by the SG device and which were deflected downwards. This lack of knowledge is captured in the density matrix that describes the result of the preparation procedure.
It depends on how you prepared that second ensemble. "Ensemble of particles of totally indeterminate spin" is vague enough to describe the results of many different preparation procedures. Some of them will be distinguishable by some measurements from first ensemble, some won't.
In modern QM state and preparation procedure are pretty much synonymous.
What you can do is entangle systems so you don't know the state of its constituent parts - in fact they don't have an individual state until entanglement is broken. Thinking otherwise often leads to difficulties with the EPR where you have some stating categorically one particle communicated with the other - the problem is they are entangled and aren't really separate entities.
Its easy to see from the formalism of entanglement. Suppose system 1 can be in state |a> and |b>. The same with system 2. Then if system 1 is in state |a> and system 2 |b> the system is in state |a>|b>. Conversely if system 1 is in state |b> and 2 in |a> that is state |b>|a>. But from the principle of superposition it can be in state 1/root 2 |a>|b> + 1/root 2 |b>|a>. They are entangled and you can't say what state either system is in until entanglement is broken.
Thanks
Bill
Likes vanhees71
Oh then I meant the one that is not distinguishable, and so my question is answered in the negative; both ensembles are prepared in that way and then the first ensemble is measured on one axis as part of the preparation, and the second ensemble is not measured as part of the preparation. Thanks.
Thanks
Bill
It is fortunate that entanglement doesn't make sense in this situation, and that I specified no entanglement of the first ensemble, in my original question.
  • #31
Others have given various ways of doing this; but none of these will give you what you said you wanted in Ensemble B, namely a "mixed" state. A mixed state is something different from what you are calling an "indeterminate" state. And the original quote you gave regarding the black hole information paradox was talking about mixed states (vs. pure states), not about indeterminate states (as opposed to determinate states).
If you still haven't picked up on my advice to consult a textbook and learn the technical meanings of all these terms you are using, do so. Once you have done so, please start a new thread if you still have questions about pure vs. mixed states. This thread is closed.
Likes vanhees71 and bhobba
Related to Is it possible to distinguish between pure and mixed states?
1. What is a pure state?
A pure state in quantum mechanics refers to a state in which a system is in a single, definite state with no uncertainty.
2. What is a mixed state?
A mixed state in quantum mechanics refers to a state in which a system is in a combination of multiple states, with some degree of uncertainty.
3. How can we distinguish between pure and mixed states?
One way to distinguish between pure and mixed states is by measuring the system. In a pure state, the measurement will always give the same result, while in a mixed state, the measurement will give different results with a certain probability.
4. Can we always distinguish between pure and mixed states?
No, there are some cases where it is not possible to distinguish between pure and mixed states. This can occur when the system is in a state of maximum uncertainty, known as a maximally mixed state.
5. Why is it important to distinguish between pure and mixed states?
Distinguishing between pure and mixed states is important in quantum mechanics as it helps us understand the behavior of quantum systems and make accurate predictions about their future states. It also has practical applications in quantum computing and quantum information processing.
