Is it possible to have water levels at different heights without a pump?
  • Thread starter Thread starter StefanBoon
    Levels Pump Water
Air cannot remain trapped under a structure with different tube heights without a pump, as the pressures from the air and water must be balanced for stability. If the downward air pressure exceeds the upward water pressure, the water level will fall, and vice versa. The diameter of the tube does not influence pressure; only the height of the water column does. An air lock can occur in inverted U-shaped tubes, where trapped air supports the water columns, preventing a siphon effect. For stability, a free-moving piston is necessary to maintain a flat water surface, and narrow tubes are essential for effective operation.
StefanBoon
I wonder if air can remain trapped under a structure that has a deep and a shallow tube. I have already tested with a prototype whether increasing volume in the shallower tube works. Air bubbles came out on the short side, so this doesn't work. Is there any way to realize this concept.
The quick answer to your question is no, but it is worth spending some time thinking about why.
Think about the forces acting on the water right at the surface: if the downwards pressure from the air above is not exactly balanced by the upwards pressure from the water immediately underneath, the level will either fall (air pressure is greater) or rise (water pressure is greater). What can you say about the air and water pressures above the two tubes?
Likes StefanBoon
Thank you, very much appreciated. What do you mean with the last sentence 'What can you say about the air and water pressures above the two tubes?'
Do you mean that it can work if the pressures of the air above is the same as de water at the surface of the short tube?
First of all I have to point out a very basic fact that it is not the diameter of the pipe that affects pressure - just the height of the vertical column.
I'm not sure if the image is the exact layout where what you describe happens (or doesn't happen) It sounds as if you are describing what's known as an 'Air Lock'. In a situation where there is air in an inverted U, the 'bubble' of air can be longer than the differences in the two water levels. The section of trapped air floats and supports the water columns so you don't get a simple siphon effect. (Plumbers come across this problem all the time where there are long horizontal runs of pipe in low pressure systems.
Practical Note: your drawing shows a flat horizontal surface at the bottom of the upper section. This is not stable and one side or the other will fall after a very short time. You would need a free moving piston to keep that water surface flat and level. You need narrow tubes to make this work.
Likes StefanBoon and Lnewqban
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
