Is My MATLAB Code for Heat Transfer Correct?
The discussion revolves around a MATLAB code for a heat transfer project, where the user is trying to determine the thermal conductivity and length of a 2D wall. The user is struggling to find a material/length combination that meets the specified heat loss and transfer rates. There are questions about calculating heat rates based on known nodal temperatures and how to plot temperature as a function of position in the wall. The code provided includes iterative loops for calculating temperature distributions and boundary conditions, but the user expresses uncertainty about its correctness. Overall, the user seeks guidance on both the code's accuracy and plotting methods.
MEAHH
Hi so i have a heat transfer project to determine the material (aka the thermal conductivity) and length of a 2d wall. It has to have between -1 and 1 net rate of heat loss from the southern side and above 145 rate of heat transfer from the eastern side. The wall is 20 cm high na the boundry conditions are given in the code...
#1 I cannot find a material/length combo that satisfys the Q rateconditions so i wonder if my code is wrong?I was really unsure of how to do the equations for the heat rate of the specified sides, how do you find the heat rate of a given side with nodal temps known, heat conduction and convection?
#2 I have to plot the temp in the wall as a function of x position for y=0,10 an 20cm...how would i do this...
Heres the code i wrote so far
%Heat Transfer Project
%Material chosen was:
%Length Chosen was:
%Inputs, Given Values in degrees C, m, and
Tn=100;
hn=20;
Te=20;
he=15;
Ts=70;
hs=30;
Tw=40;
hw=20;
H=0.2;
L=.5;
k=0.14;
I=21;
J=21;
%Geometry
deltax=L/(I-1);
deltay=L/(J-1);
x=[0:0.1:L];
y=[0:0.1:H];
A=L*H;
%Iterative loop
T=ones(I,J)*Tw;
Dum=1;
while Dum==1
Told=T;
%Numeric Equations
%Interior Control Volumes
for i=2,I-1;
for j=2,J-1;
T(i,j)=(k*deltay*T(i-1,j)+k*deltay*T(i+1,j)+k*deltax*T(i,j-1)-k*deltax*T(i,j+1))/(2*k*deltay+2*k*deltax);
end
end
%West & East sides
for j=2,J;
T(1,j)=(-hw*deltay*Tw-(k*deltax)/(2*deltay)*T(1,j+1)-(k*deltax)/(2*deltay)*T(1,j-1)-(k*deltay)/deltax*T(2,j))/(-hw*deltay-2*((k*deltax)/(2*deltay))-(k*deltax)/(deltay));
T(I,j)=(-he*deltay*Te-(k*deltax)/(2*deltay)*T(I,j+1)-(k*deltax)/(2*deltay)*T(I,j-1)-(k*deltay)/deltax*T(I-1,j))/(-he*deltay-2*((k*deltax)/(2*deltay))-(k*deltax)/(deltay));
end
%South & North
for i=2,I;
T(i,1)=(-hs*deltax*Ts-(k*deltay)/(2*deltax)*T(i+1,1)-(k*deltay)/(2*deltax)*T(i-1,1)-(k*deltax)/deltay*T(i,2))/(-hs*deltax-2*((k*deltay)/(2*deltax))-(k*deltay)/(deltax));
T(i,J)=(-hn*deltax*Tn-(k*deltay)/(2*deltax)*T(i+1,J)-(k*deltay)/(2*deltax)*T(i-1,J)-(k*deltax)/deltay*T(i,J-1))/(-hn*deltax-2*((k*deltay)/(2*deltax))-(k*deltay)/(deltax));
end
%Four Coners
T(1,1)=((-hw*Tw*deltay)/2-(hs*Ts*deltax)/2-(k*deltay)/(2*deltax)*T(2,1)-(k*deltax)/(2*deltay)*T(1,2))/(-(hw*deltay)/2-(hs*deltax)/2-(k*deltay)/(2*deltax)-(k*deltax)/(2*deltay));
T(I,1)=((-he*Te*deltay)/2-(hs*Ts*deltax)/2-(k*deltay)/(2*deltax)*T(I-1,1)-(k*deltax)/(2*deltay)*T(I,2))/(-(he*deltay)/2-(hs*deltax)/2-(k*deltay)/(2*deltax)-(k*deltax)/(2*deltay));
T(1,J)=((-hw*Tw*deltay)/2-(hn*Tn*deltax)/2-(k*deltay)/(2*deltax)*T(2,J)-(k*deltax)/(2*deltay)*T(1,J))/(-(hw*deltay)/2-(hn*deltax)/2-(k*deltay)/(2*deltax)-(k*deltax)/(2*deltay));
T(I,J)=((-he*Te*deltay)/2-(hn*Tn*deltax)/2-(k*deltay)/(2*deltax)*T(I-1,J)-(k*deltax)/(2*deltay)*T(I,J-1))/(-(he*deltay)/2-(hn*deltax)/2-(k*deltay)/(2*deltax)-(k*deltax)/(2*deltay));
%Check for convergence
Dum=0;
for i=1,I;
for j=1,J;
if (abs((Told(i,j)-T(i,j))/T(i,j))>0.0000001)
Dum=1;
end
end
end
end
Qe=he*deltay*[(T(I,1)-Te)/2+(T(I,2)-Te)+(T(I,3)-Te)+(T(I,4)-Te)+(T(I,5)-Te)+(T(I,6)-Te)+(T(I,7)-Te)+(T(I,8)-Te)+(T(I,9)-Te)+(T(I,10)-Te)+(T(I,11)-Te)+(T(I,12)-Te)+(T(I,13)-Te)+(T(I,14)-Te)+(T(I,15)-Te)+(T(I,16)-Te)+(T(I,17)-Te)+(T(I,19)-Te)+(T(I,20)-Te)+(.5*T(I,J)-Te)]
Qs=hs*deltax*[(T(1,1)-Ts)/2+(T(2,1)-Ts)+(T(3,1)-Ts)+(T(4,1)-Ts)+(T(5,1)-Ts)+(T(6,1)-Ts)+(T(7,1)-Ts)+(T(8,1)-Ts)+(T(9,1)-Ts)+(T(10,1)-Ts)+(T(11,1)-Ts)+(T(12,1)-Ts)+(T(13,1)-Ts)+(T(14,1)-Ts)+(T(15,1)-Ts)+(T(16,1)-Ts)+(T(17,1)-Ts)+(T(19,1)-Ts)+(T(20,1)-Ts)+(.5*T(I,1)-Ts)]
And what are your units?
On an aside, it's so warm in my room - it's like 28. And it's been warm for a while too - for almost 4 now. I tried to cool things down a bit by opening a gap in my window - a gap of 2.
Now - good luck deciphering that.
And then they wonder why nobody wants to hire american engineers anymore.
I added [ code ] and [ /code ] tags (without extra spaces).
Code:
%Length Chosen was:
Tn=100;
hn=20;
Te=20;
he=15;
Ts=70;
hs=30;
Tw=40;
hw=20;
H=0.2;
L=.5;
k=0.14;
I=21;
J=21;
%Geometry
deltax=L/(I-1);
deltay=L/(J-1);
x=[0:0.1:L];
y=[0:0.1:H];
A=L*H;
%Iterative loop
T=ones(I,J)*Tw;
Dum=1;
while Dum==1
    Told=T;
%Numeric Equations
for i=2,I-1;
    for j=2,J-1;
    end
end
%West & East sides
for j=2,J;
end
%South & North
for i=2,I;
end
%Four Coners
Dum=0;
for i=1,I;
for j=1,J;
        Dum=1;
    end
end
end
end
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
