Is My Procedure for Calculating Water Density in a Chemistry Lab Correct?
The discussion focuses on the correct procedure for calculating water density in a chemistry lab. The primary task involves measuring the mass of water at various volumes to verify that mass is directly proportional to volume, confirming the density remains constant. For accurate results, participants suggest using a graduated cylinder to measure mass before and after adding specific volumes of water, with expected density values around 1.0 g/mL. The conversation also touches on the definition of "graduated" glassware, clarifying that it refers to precise measuring marks. Overall, the procedure and understanding of density measurement are affirmed as correct.
lolzwhut?
I'm curious if I'm doing this chemistry lab correctly or not. If you open the link below, you can see the lab. Basically, my job right now is to write a well formulated procedure on how to perform this lab.
So, for this lab, am I supposed to be calculating the mass of the substance (h2o in this case) in the provided methods for 3 trials? What I don't quite get is how to verify that the mass is directional proportional to its volume. I feel very unsure about my procedures I wrote. So if anyone can, would they mind checking the lab and steer me in the right direction or atleast verify if what I'm doing is right?
Thanks in advance.
https://viewer.zoho.com/docs/uaBiK"
This is just a study of density, which is a property of a substance. The density is how much mass for a given volume, thus having units of grams per milliliter (g/mL = g/cm^3). At the same temperature and pressure this property is always constant provided the substance is chemically the same every time (i.e. no other chemicals were added during trials 2 and 3).
For water at 1 atm and 25 C the density is approximately 1.0 g/mL.
Verifying that the mass is always proportional to the volume is easy. You are just measuring the density at different volumes and if they are the same then you've succeeded.
For example, first get the mass of a graduated cylinder and then pour 10 mL water into it and take the mass again. Now you have [(Mass water & cylinder) - (Mass Cylinder)]/10 mL = Density of water g/mL.
Next repeat this using 7 mL of water and then 9 mL. You will get the approximately the same number!
Maybe you will get
trial 1 = 0.995 g/mL
trial 2 = 0.990 g/mL
trial 3 = 0.998 g/mL
Which is correct! You should be somewhere in this range!
Thanks, I was right :) I even asked the teacher, he confirmed it. Also, there's this odd question...
"What does it mean when you a piece of glassware that is "graduated" or has "graduations" on it?" Couldn't we describe graduations as precise measuring marks?
We can, just note that you can have a single volume or multiple volumes calibrated glass.
Compare http://www.titrations.info/pipette-burette for more details about calibrated glass.
Just curious, but why are we dividing by 10? FYI, I'm taking the temperature in Fahrenheit.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
