MHB Is my solution for the tank word problem correct?
  • Thread starter Thread starter paulmdrdo1
    Tank Word problem
The discussion centers on solving a tank word problem involving two pipes and a drain. The larger pipe fills the tank in 40 minutes, while the smaller one takes 50 minutes, and the goal is to find the drain's emptying time when the pipes are closed. The proposed solution uses the equation $\frac{1}{40}+\frac{1}{50}-\frac{1}{x}=\frac{1}{36}$ but faces criticism for incorrect multiplication and assumptions about the conditions. Specifically, the use of 72000 as a multiplier is questioned, with suggestions that 1800 or 7200 would be more appropriate. The conclusion indicates that the initial calculations and assumptions need revision for accuracy.
paulmdrdo1
please check my work here
1. The larger of the two pipes can fill a tank in 40 min. and the smaller can fill it in 50 min. while the drain is opened. Find the time required for the drain to empty the full tank if the pipes are closed.
Solution
$\frac{1}{40}+\frac{1}{50}-\frac{1}{x}=\frac{1}{36}$---> multiply this by 72000x
$1800x+1440x=74000$
$3240x=74000$
where $x=$ the time required for the drain to empty the tank
solving for x I get $x=22.83\text{min}$
is my answer correct?
Mathematics news on Phys.org
Solution
Did you forget to write another condition that has to do with 36 minutes? Next, why multiply by 72000 when the LCM(40, 50, 36) = 1800? At most 7200 will do.
paulmdrdo said:
$1800x+1440x=74000$
After multiplying by $72000x$, the right-hand side is $2000x$, not just $2000$, so this equation is wrong.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
51K
