Is my understanding of the answers given correct?
  • A
  • Thread starter wittgenstein
In summary,Hawking said that the uncertainty principle is a physical principle that indicates the degree to how well we can possibly know something. He noted that it is not that particles lack a position and momentum; rather, we will always be uninformed about either of these properties. However, this does not seem to be a particularly remarkable statement. Many physicists believe that the uncertainty principle is a cornerstone of quantum theory, but it is not clear why this is the case.
wittgenstein
222
TL;DR Summary
From all the answers I have received it seems that there is nothing amazing about QM. there is no need for many worlds etc.
I posted a question on Ask A physicist and he replied, "If the uncertainty principle is correctly stated, it is a correct physical principle which indicates the degree to how well you can possibly know something.
So its just that we cannot know simultaneously what a particle's position and momentum is. It is not that they lack a position and momentum. That seems very mundane. It doesn't tell us anything about matter it tells us only that we will always be uninformed about either the position or the momentum. There is no need for such extravagant explanations as "That is, as it [the particle] moves from its starting point A to some endpoint B, it doesn’t take one definite path, but rather simultaneously takes every possible path connecting the two points."
Hawking the grand design
Since my question was, is the uncertainty intrinsic ( that the particle has no position and/or momentum ) or is the uncertainty merely a measure of what we can know and the answer was ( see bold font ) it seems that there is nothing remarkable here. Why do physicists keep saying that QM violates common sense etc?
Nobody knows which of the two interpretations is right. If the second one (that uncertainty is just our inability to know things which are objectively there) is true, then one naturally asks why exactly we cannot know them. And when you try to make an elaborated answer, it turns out that each possible answer violates common sense one way or another.
wittgenstein said:
Summary:: From all the answers I have received it seems that there is nothing amazing about QM. there is no need for many worlds etc.
It's impossible to work out from that when you are quoting some anonymous physicist, when you are quoting Hawking and when you are making your own claims about QM.
This thread is another example of the dangers of this sub-forum where the impression is given that quantum particles, ultimately, have well-defined trajectories. And, that classical physics is thereby restored, if only peppered with an ounce or two of experimental uncertainty.
Well-defined (realist) trajectories may be restored in Bohmian Mechanics, but only at the price of other distinctly non-classical assumptions.
In most QM interpretations, particles do not have well-defined trajectories - and, indeed, that is seen by many physicists as a cornerstone of quantum theory. And not just some experimental quirk.
Likes mattt, martinbn, gentzen and 1 other person
Some anonymous physicist ? Stephen Hawking is not well known? I also gave the source, his book , " The Grand Design."
You've constructed the dubious proposition that Hawking either did not believe in QM or believed in some realist interpretation (such as Bohmian mechanics). That proposition is false. You have taken a quotation from Hawking's popular science book out of context.
In any case, this is yet another thread where the fundamentally non-classical nature of QM is called into question, under the pretext of discussing "interpretations".
Likes weirdoguy
Suppose there is a dark room that I cannot see into. I send basketballs into it. They ricochet out of the room. I will not be able to tell both the position and momentum of the objects that they ricocheted off of. That seems analogous to me of firing particles in the 2 slit experiment. There is nothing mysterious going on. I do not have to propose multiple universes etc.
I am confused. So Hawking was not claiming that the particle is in all places?
Yes, I am questioning QM. Is it bad to try to understand it? My basic question is, is QM actually almost classical except that our influence on the results of an experiment are unavoidable.
  • Skeptical
Likes weirdoguy
The question is labled 'A', which means grad school level. The question itself seems to be based on popular expositions of physics. It should be 'B'.
Likes PeroK
I posed my question without clarity previously. I will try to be clearer;
Yes, I am questioning QM. Is it bad to try to understand it? My basic question is, is QM actually almost classical except that our influence on the results of an experiment is unavoidable.
Suppose there is a dark room that I cannot see into. I send basketballs into it. They ricochet out of the room. I will not be able to tell both the position and momentum of the objects that they ricocheted off of. That seems analogous to me firing particles in the 2-slit experiment. There is nothing mysterious going on. I do not have to propose multiple universes etc. Why is any extraordinary explanation needed?
I apologize for not making my question clear.
Which is totally and utterly wrong.
It's a popular science source. That's why such sources are not acceptable here.
Likes DrClaude
What do you mean by questioning QM? If you believe that it s wrong, you are in the wrong place. You need to go to crackpotforums.com.
PeroK said:
Which is totally and utterly wrong. It's a popular science source. That's why such sources are not acceptable here.
So we should ignore Hawking's books? Was he lying?
So no questions about QM allowed! WOW! All I asked was why such extraordinary explanations are needed.
You, yourself, should ignore them, they are obviously confusing you. No, Hawking is not lying, he is oversimplifying.
Likes PeroK
If you label the question as 'A' level, you should be familiar with graduat leve QM. Are you?
Likes Motore
Note that I am not saying that QM is classical and that the uncertainty principle is only because it is unavoidable to influence the experiment. I am asking a question.
Of course some will say that I am ignorant and have no right to ask such questions. I disagree.
I think you should check what "questioning" means. And it does not mean "asking questions".
We've had this argument before - so many times on this forum. QM was not invented out of the blue. It was developed to explain extraordinary experimental results that could not be explained classically.
This is what it means for physics to be an empirical science. It's not philosophy. It's not just something that you make up out of pure thought. It has to match experiment. The experimental results are non-classical and so any theory that successfully explains them must be non-classical. If you want to replace "non-classical" with "extraordinary", then go ahead.
QM is all based on experimental evidence (over 100 years of it now).
Likes mattt, Lord Jestocost, DrClaude and 1 other person
No, this is wrong. Any undergraduate textbook will tell you that.
? I am asking questions. BTW if I have faith in QM or not has nothing to do with the validity of my questions. Where did I say that QM was wrong? I am sure that there is an explanation as to why physicists say that QM needs extraordinary explanations. I just want to hear them. BTW please let's not make this discussion personal. All I want is an answer to my question. There is no reason to be so defensive.
Again - check in the dictionary what does "questioning" mean. Then you'll know why people interpreted you posts that way.
QM is not politics. It is not democratic. If you refuse to learn QM even at undergraduate level, then you have no equal rights to be taken seriously. It's the same as any scientific discipline: medicine, engineering, cell biology etc. The first step is to learn the subject.
? I agree. QM is not politics. What is your point? How can I learn if asking questions is not allowed? I thought that was what this site is about.
I am asking why such extraordinary explanations of QM are needed. Asking that is politics and not allowed?
This was already answered. The explaanations have to match the observations. They are what they are because that is how nature is. Why they seem extraodinary to you? I can only speculate: it's because you haven't put in the effort to learn some QM.
Likes PeroK
Anyway, it is obvious that I am so stupid that I should not be allowed to ask that question. BYE
  • #31
I hope you are headed to the library to get a QM book.
Likes weirdoguy
  • #32
Because a simpler explanation will suffice. We cannot help but influence our experiments. We do not need many worlds etc. Its just that we influence the results of an experiment and cannot delete that influence. Why does " many worlds" seem extraordinary to me?
  • #33
Ok, other than the popular books, which QM textbook have you tried to study?
  • #34
Anyway, you are making this discussion personal. You really should be less defensive. All I asked was why such extraordinary ( I find Many worlds extremely extraordinary. that there are many planets in other universes with duplicates of me. That doesn't sound extraordinary to you? , I am also including the idea that a particle is everywhere and Wigner etc ) explanations are needed.
  • Sad
Likes Motore
  • #35
OK I typed too fast. I should have said, " Will a simpler explanation suffice. "
