- #36
- 8,943
- 2,953
Boston_Guy said:Yes. That is how its defined in the GR literature. e.g. Principle of Equivalence, F. Rohrlich, Ann. Phys. 22, 169-191, (1963), page 173
I think that doesn't really make any sense. And the fact that something appears in the literature doesn't by itself make it sensible. If you look at how the equivalence principle is actually used in physics, it doesn't have anything to do with curvature. The way it's actually used (this is the way Einstein used it originally) is to predict (approximately) how clocks and other physical things behave on Earth by comparison with a rocket accelerating in flat spacetime. That use does not depend on curvature vanishing (it doesn't vanish on the Earth). What it depends on is that the specific experiment under consideration must be insensitive to small changes in the gravitational field.
If you conduct an experiment confined to a small volume of space for a small duration of time, and the variation of the gravitational field within that volume is negligible, then the results will be the same as if one performed the same experiment confined to a small volume of an accelerating rocket, provided that the length [itex]L[/itex] is small enough that [itex]\dfrac{g\ L}{c^2}[/itex] is negligible. Curvature doesn't really enter into it. Whether the variation of gravity within a volume is negligible depends on the size of the volume, but curvature doesn't depend on the size of the volume.
This is what allowed Einstein to make the prediction of gravitational time dilation and gravitational redshift BEFORE he had developed the full theory of GR. In particular, it was before he had the field equations, and before he associated "gravity-free space" with "zero curvature".
If you consider a rotating coordinate system, there are "fictitious gravitational forces" such as the Coriolis force and the Centrifugal force. I think it would be weird to call those forces "uniform", even though the curvature tensor is perfectly zero. The real criterion for the usability of the equivalence principle is whether the variation of the "gravitational forces" are negligible within the volume under consideration.
