Is overcharging of mobile battery real ?
  • Thread starter Thread starter Frenemy90210
    Battery Mobile
Overcharging mobile batteries can damage older battery types, potentially leading to reduced capacity or even physical deformation. However, modern batteries equipped with intelligent charging circuitry can handle being connected to a charger indefinitely without risk of damage. While batteries do experience stress when fully charged and hot, the impact on lifespan is minimal, with only a slight reduction in charge cycles. It is advisable to charge devices at convenience without concern for overcharging, as they are designed for such use. Overall, modern charging systems effectively mitigate the risks associated with overcharging.
Frenemy90210
I think max. voltage of a mobile battery is 4.3 V and voltage of a USB charger is 5 V; My question is , if we keep the charging process on even after mobile battery is 100 % charged, is it true that it will damage the battery ? Does it reduce the life of a battery or does it reduce the charge holding capacity ?
Hey Frenemy90210,
Some older types of batteries could indeed be damaged by keeping them connected to a high voltage even after they had reached 100% charge. Some older batteries would simply lose capacity. It was even possible for a battery's electrolyte to decompose, causing gases to be generated. The gases could physically damage the structure of the battery, and make it deform or explode.
The answer is very different for modern battery systems -- the kind you would charge over USB. Modern battery systems have intelligent charging circuitry built directly into the battery cells, and there are microcontrollers in both the charger and device that constantly monitor the charging process. These systems are really smart! You can leave a USB charger connected to your device indefinitely with no risk.
It is true that batteries experience the greatest stress when they are hot, and when they are fully charged. You can keep your battery healthy for more charge cycles if you keep it cool and don't leave it 100% charged all the time. This effect is fairly small, though -- you might get 650 charge cycles instead of 600.
My best advice? Charge your device whenever it is convenient, and don't worry about it. The batteries and chargers were designed for that kind of use.
Likes NascentOxygen and Greg Bernhardt
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
