I Is ##p^k = \partial L / \partial \dot{x}^k## true for all ##L##'s?
The discussion centers on the relationship between generalized momentum and the Lagrangian in classical mechanics, specifically questioning whether the equation p^k = ∂L/∂dot{x}^k holds for all Lagrangians. An example using the Lagrangian L = T - U = (1/2)mv^2 - U demonstrates that the equation is valid for this case, yielding p^k = m dot{x}^k. The conversation seeks to establish a general proof for this relationship across all Lagrangians. A reference to generalized coordinates is provided to support the discussion. The inquiry highlights the need for a deeper understanding of momentum definitions in the context of Lagrangian mechanics.
Kostik
TL;DR Summary
Is the relation Is ##p^k = \partial L / \partial \dot{x}^k## true for all Lagrangians?
Using the Lagrangian $$L=T-U=\frac{1}{2}mv^2-U$$ we clearly have $$ \frac{\partial L}{\partial \dot{x}^k} = m\dot{x}^k = p^k $$ i.e., the ##k##'th component of momentum. How does one show that the relation $$p^k = \frac{\partial L}{\partial \dot{x}^k} $$ holds for all Lagrangians?
“The generalized momentum "canonically conjugate to" the coordinate qi is defined by
{\displaystyle p_{i}={\frac {\partial L}{\partial {\dot {q}}_{i}}}.}
https://en.m.wikipedia.org/wiki/Generalized_coordinates
Thanks. I did not phrase the question very well. I have made a more detailed post of the question here:
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
