I Is RMS speed dependent on pressure?
RMS speed is primarily dependent on temperature rather than pressure for a given gas. Increasing pressure does not directly change the RMS speed if temperature remains constant. However, if pressure is increased through compression, it typically involves work done on the gas, which can lead to an increase in temperature and thus an increase in RMS speed. The discussion highlights that while pressure affects gas particle motion, it does not alter RMS speed without a corresponding temperature change. Ultimately, the relationship between pressure and RMS speed is nuanced and contingent on the conditions of the gas.
phymath7
TL;DR Summary
One question appeared in my test.It asked that if pressure of two gases are increased to two times of the previous,then how much change would happen to the ratio of the r.m.s speed of the two gases keeping the temperature constant?
As it is clear from the formula for r.m.s speed ,it is only dependent of temperture for a particular gas,I think the answer should be "No change happens".But I wonder whether there is more insight to this.And is my assumption true?
Science news on Phys.org
phymath7 said:
TL;DR Summary: One question appeared in my test.It asked that if pressure of two gases are increased to two times of the previous,then how much change would happen to the ratio of the r.m.s speed of the two gases keeping the temperature constant?
You are correct.
I think that the insight is that one could think adding pressure will affect the motion of the gas particles, and hence their speed. (A higher pressure will affect the motion in some way. Can you see what it is?)
DrClaude said:
You are correct.
So you are saying that a higher pressure will somehow affect the r.m.s speed?But I don't see how it happens right now.
If temperature is not forced to remain constant then consider how you go about increasing the pressure of the gas. Do you, for instance, force a piston further into a cylinder?
No, it doesn't affect r.m.s. speed, as you noted yourself. But it does affect something else related to the motion of the molecules.
Just apply the first law: ##\Delta U = Q+W## where W is the work done on the gas and Q is the heat flow into the gas.
A higher pressure without a change in volume (W=0) can only be achieved by increasing temperature (##\Delta U>0##) by positive heat flow (Q>0). Higher T means higher molecular rms speed (higher average molecular translational KE).
A higher pressure with compression requires positive work to be done on the gas (W>0). So if it is done adiabatically (Q=0) ##\Delta U>0## which results in higher molecular rms speed.
The only way to increase pressure without increasing molecular rms speed (##\Delta U \le 0##) is to compress with ##Q+W\le 0## (ie. heat flow out of the gas is greater than or equal to the work done on the gas).
AM
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
